I have a light that is operated by two switches. One is upstairs, and the other is down stairs. How can I make the light work by either switch? Currently if I turn the light on down stairs, I cannot turn it off upstairs.
Please advise.
whatsisname
  • 2,289
    If you are comfortable with wiring, you could describe what the wires connected to each switch now are, and we might be able to advise whether it seems possible to (or simply desribe how it should be wired to) make it work as desired. "Three way switch" is the usual terminology, and there will be several questions/answers about those if you look around here. If you're not comfortable with wiring, the answer is simply to have an electrician make it right. You probably either have a miswired three way switch arrangement, or some sort of "handyman special" where three way switches were not used. – Ecnerwal May 28 '15 at 20:05
    Was this always this way, or has this problem arisen only recently? – Joel Keene May 28 '15 at 20:21
    See past answers about "three-way" switch circuits. There's one in particular where I describe why the common error of connecting one of the switches "backwards" can cause this, and how to fix it by blind experimentation if you don't know how to deal with it in a more organized manner. Unfortunately finding and pointing to past answers is awkward in the Android app. – keshlam May 28 '15 at 20:53
    @keshlam probably refers to [Why isn't this 3-way wiring working?](http://diy.stackexchange.com/a/52683/2815) – RedGrittyBrick May 28 '15 at 23:05
Sounds like a mis-wired 3-way switch. I had one in my house when I moved in that did that. Have a look at my answer to this related question: How should I rewire a miswired 3-way switch?
KeithS
  • 14,107
  • 73
