I've been getting very high electric bills since moving in last August. My winter months have averaged $350/mo and so far this spring has been the same. I live alone, work 8 hours a day, do 2 loads of laundry per week, rarely use the stove for baking, and my temperature in winter months is set at 68-69 deg, and in summer 72-73 degrees. The house remains comfortable for me. I don't watch a lot of TV or have a lot of appliances going regularly.
About the house:
  • Built in early 1990s
  • 1480 sq ft
  • 2x6 exterior walls
  • crawl space
  • geothermal heating, closed loop (unit is 2 years old, piping is over 10 years)
  • loose insulation in attic, about 10-12" thick (not the roll out type)
  • insulated garage
  • front entrance has vestibule (exterior door and interior door into living area)
  • laminate flooring, tile in bathrooms
  • high efficiency washer/dryer (new this year)
  • all electric appliances
  • rarely use the oven, just stove top, microwave
I was told geothermal systems were very efficient and people with 2k sqft homes were paying $80-100 for heating/cooling costs. I also leave the temperate the same throughout the day as told by the geothermal company and previous owners as its most efficient.
My neighbor has a similar sized house, with natural gas heating, and his total utility is half of what I pay. He also keeps his house a bit warmer (wife complains) in the winter months. This really ticked me off so I contacted my geo company and they came out to inspect the unit. Nothing was found wrong with it and the flow rate/psi/etc was all tested fine. I'm not seeing the savings with geothermal at all.
As I've mentioned, my house does not get a draft at the front door because of having a vestibule. My garage is insulated and I feel no draft coming in at the garage door or interior garage door. My two exterior doors in the rear both go into a sun room, so again, no cold/hot draft coming in. My windows are all sealed and I feel no cold/hot air coming in. Even using a thermal sensor, it was very efficient. I'm not seeing any leaks on the exterior walls. The three weak spots are - my hallway has an attic fan and the other hallway has the attic stair pull down. The fan area seems to be letting heat pass through, but not as bad as the flaps are closed. The crawl space has no insulation, but I can't see that being a big factor in the winter months as heat rises.
Majority of lighting in the house uses LED. I have a few CFLs but they are hallway lighting and set on a 1 minute timer.
Water heater is in the conditioned area of my house. Only the water pump is in the crawl space.
Other than possibly insulating the crawl space and sealing up the attic entrance better, I can't see how much more I can seal up the inside of the house.
What else can I do to with the house to be more efficient? Is it worth investing in a standard HVAC system?
Kansas City Metro Area
Last bill:
Avg Temp - mid 60s
2701 kWh Used = $231.92
Customer Charge = 10.71
ECA 64.76
ECA 1.91
EER 0.43
PTS 2.48
Taxes 23.92
Surge Protection 8.83
(Edited for more information)
wallyk
  • 12,319
user1052448
  • 227
    What are the outdoor temperatures like in your area? – Tester101 Jun 04 '15 at 15:24
    What are you paying per kilowatt hour (should be on the electric bill)? – Tester101 Jun 04 '15 at 15:28
  • ...note that the charges for electricity may be broken up into various categories like "supply", "delivery", "taxes", etc. There may not be an obvious total rate, but the bill should list the total kW-hr. Divide the total $ by the total kW-hr to get the approximate rate, if it's not explicitly listed. – Hank Jun 04 '15 at 15:30
  • I wrote out the breakdown of my bill. I get seasonal rate so its a bit cheaper. The cut-over happened in mid-late May. – user1052448 Jun 04 '15 at 15:44
  • So I arrived home early to do a baseline test. At 2:21pm my meter read 17363. For the next hour I will do absolutely nothing at home and compare the readings every 30 minutes. Then at 5pm I will go about my usual duties and compare every 30 minutes until bed time. Going to see what I use and how that affects my utility. Then tomorrow I'm going to start flipping breakers before work and compare after work. – user1052448 Jun 04 '15 at 19:30
  • At 2:51pm 17365 – user1052448 Jun 04 '15 at 20:11
  • At 3:21pm 17367. So it looks like 4kWh is what i'm consuming without doing anything in the house. That's 48kWh a day. – user1052448 Jun 04 '15 at 20:24
  • At 3:51pm 17370 – user1052448 Jun 04 '15 at 21:09
  • Are you running humidifiers, whole house fans, grow lamps, hot tubs, or any other high draw equipment? – Tester101 Jun 04 '15 at 22:59
  • At 6:21pm 17383 (only difference from here to 3:51 is I took a shower, ran the microwave for 3 minutes, and toaster oven at 300F for 4 min). – user1052448 Jun 04 '15 at 23:24
  • I do not have any of those except whole house fan, and I never turn it on. – user1052448 Jun 04 '15 at 23:24
  • I'm at 6:51pm with 17387 now. And that's with one breaker off. I now shut off both bedrooms and hallway (don't use that side of the house anyway) and will report back in 30 minutes. At this moment, I don't think its my geothermal system anymore. – user1052448 Jun 05 '15 at 00:09
  • Is your water heater electric? Are you on well, or municipal water? Are you running any water filtration systems? – Tester101 Jun 05 '15 at 01:16
  • I have city water. Electric water heater rated at $514 per year. At 9:08am I'm at 17427. – user1052448 Jun 05 '15 at 14:52
  • So I printed out an energy audit form online and according to my zone I should have R49 in the attic. I'm not even at half of that. My blown-in insulation just reaches the top of the joists. I'm not sure how much 18" of calculated extra insulation costs or will help, but that may be an area I'm wasting a lot of energy. – user1052448 Jun 05 '15 at 14:53
Upon replacing my air filter, I noticed some warm air in the air handler. My strip heat was stuck on causing the problem the entire time. Company is replacing the circuit board.
  • Hell, that sucks! At least you found the problem. I sincerely hope you have many years of below $50 utility bills. – wallyk Jun 25 '15 at 22:50
  • That's a surprisingly common problem. :( Glad you got it figured out! – iLikeDirt Jun 25 '15 at 22:59
  • Well it has been off since 1pm now (pulled the wire from the thermostat). So I'm going to keep an eye on the power usage at the utility meter. From 10:30am until 9:30pm I've consumed 77kWh which is roughly 7 per hour, so it seems like I'm still consuming a lot. I'm assuming my unit is working harder to cool things back down. Tomorrow I will monitor it for 24 hours and see if my usage has gone down to a "normal" state. – user1052448 Jun 26 '15 at 02:42
From your bill, you're using about 90 kWh a day. That's completely insane. My entire 3-person family uses about 5 a day. The fact that you're using 2700 kWh a month when it's in the 60s outside tells me that your ground-source heat pump should barely be running at all, so it's probably not that. Furthermore it sounds like your house is reasonably well insulated and air sealed, so that's another sign that it's probably not the heat pump that's using all the power. However, if you're using 90 kWh a day, that's the equivalent of adding 307,000 BTUs of heat to your house. This is heat that your heat pump will have to remove if it's hot! So all this electricity usage is hurting you whenever it's not deathly cold.
So what's using up all that electricity? The first step is to actually figure that out. Don't guess or tell yourself, "I have efficient appliances!" Anything with a plug you can measure it with a kill-a-watt meter. Anything else, you can turn off the breakers one-at-a-time and see which ones make the biggest impact on slowing down the meter. At 90 kWh a day, it's probably spinning like crazy, so you should see an immediate impact when you find the circuits that are feeding the power hogs. You may have some things that use a lot of power that run 24 hours a day. Cable boxes, TVs, humidifiers, dehumidifiers, things like that. Measure everything!
It's also possible that something is wrong with your electrical system itself. I'd call the power company. If you tell them you're using 90 kWh a day with no apparent high loads, they'll come out there real quick to investigate.
Finally, and I hate to say it, but whoever told you that a ground-source heat pump ("geothermal") will save you money was selling you a load of crap. Ground-source heat pumps are notoriously finicky. Whether they'll save you any money heavily depends on a host of factors, including your electricity and natural gas prices, the cost of the system, and the standby load of the equipment itself. Inefficient ones may have pumps that constantly draw 80 watts; a good one might only draw 5 or 10. It does not surprise me in the least bit that a gas furnace would produce heat more cheaply than a ground-source heat pump in this era of historically-low natural gas prices. But if you've already got one, it doesn't make any sense to remove it if it's working properly.
iLikeDirt
  • 12,543
  • 52
  • I will try flipping breakers and see. I have measured my fridge and it averages about 1kWh per day. Out of the 3 bedrooms, mine is the only one being used. And I only have my iPhone charged at night. I doubt doing 2 laundry loads per week is consuming that much, with HE or not. I'm also going to try turning the geothermal system off for 24 hours at the breaker and another day at the thermostat and compare. But I know when I had it set to 76 degrees one day in the spring, my daily usage barely dropped. – user1052448 Jun 04 '15 at 16:15
    Power company doesn't want to come out. They claim their meter is working fine. They are going off of last years bill from previous owner and it matches up. But I tell them just because it matches up doesn't make it right. The problem could've existed before but they never complained. – user1052448 Jun 04 '15 at 16:20
  • Exactly. Sounds like you need to bug them some more. :) – iLikeDirt Jun 04 '15 at 16:24
  • My utility shows daily usage as well. Some days I have 134 and some days 58. The 134 happens when I'm at work, so not sure what's going on. Maybe I have a neighbor stealing power.. – user1052448 Jun 04 '15 at 17:13
I hear you loud and clear. When we built our 1800 sf house 12 years ago we were sold on geothermal by the builder, telling us it would cost us avg $50 a month. Never happened. We pay Detroit Edison, using Budget $250 per month. We are now using a radiant (no fan) space heater in the great room and keeping thermostat on 66*. We live in Michigan and it is cold here. This has saved us 20-25% off our electric bill this spring. Only started doing this.
As ILikeDirt says below you need to use a KillAWatt or other meter to determine where the electricity is going, circuit by circuit, outlet by outlet. Unfortunately, electricity monitoring is not easy to do, especially if the culprit is a big appliance that is hard-wired to the panel.
You could try something like this system from Plugged Solar:
Basically the strategy is to monitor each circuit. So, you remove the panel cover. Behind it looks like this:
breaker box
You see those wires going into each breaker? Those are the hots, you want to measure them over time. You put the clamps over those wires (being careful not to electrocute yourself in the process) and then measure for a week or so. Then switch the clamps to another circuit. Eventually you will figure out which circuit is sucking down all the energy.
Note that there is another system called TED, that has a "spyder" for measuring each circuit at the same time. This is definitely better than trying to measure it one at a time. The system is pretty pricey though. The spider looks like this:
TED spyder
Tyler Durden
  • 6,789
  • 49
  • 98
  • I have the plug-in meter and I've tested the big items in the house that aren't hard wired and I'm not seeing anything that has a big drain. My water heater has a dedicated breaker so when I get home I will watch it for an hour and then use hot water and watch it again for an hour and see. – user1052448 Jun 04 '15 at 17:10
  • @user1052448 There could be a partial short which will not only drain electricity, but is a fire hazard. To find it, you need to test the circuits. – Tyler Durden Jun 04 '15 at 19:35
    I don't have any breakers that trip. So is a short still likely? – user1052448 Jun 04 '15 at 20:14
  • @user1052448 In a partial short, the electricity just leaks out. The breaker only trips if the circuit is completely shorted out. – Tyler Durden Jun 04 '15 at 21:23
  • Interesting. How can I test the circuit for partial short? – user1052448 Jun 04 '15 at 23:25
  • @user1052448 By measuring how much electricity it is consuming. If that amount is a lot more than is being consumed by the devices attached to the circuit it means there is a short somewhere and electricity is flowing into some other place, like a water piper or conduit. Also, a partial short can be inside a defective appliance. In that case the appliance will just seem to be consuming way more electricity than normally and its case may be physically hot in temperature. – Tyler Durden Jun 05 '15 at 00:56
  • What the heck is a "*partial short*"? – Tester101 Jun 05 '15 at 01:32
  • @Tester101 A partial short is when electricity is flowing to someplace it should not. For example, if a bare wire is touching wood, electricity can flow into the wood. Also, sometimes a fitting will get corroded. The corrosion acts kind of like a resistor and electricity can flow through it to ground. – Tyler Durden Jun 05 '15 at 01:40
  • You mean a high impedance fault? – Tester101 Jun 05 '15 at 02:15
  • @Tester101 Normally that term is used in the context of commercial or grid power lines, but I guess it is the same idea. A breaker will only trip if the current exceeds some certain amount like 15 or 20 amps. If the short has a current flow less than that, like say, 5 amps, it will just keep going and going right into the wood or wherever it is going. – Tyler Durden Jun 05 '15 at 02:41
  • So I should unplug the appliance, check if there's still current. If not, then I know the wiring is good. If the appliance is plugged in but off, and I'm having a good amount of current, then its safe to assume that the appliance is faulty. I doubt a stove or dishwasher powered off is consuming more than 0.1A. At least not a basic one manufactured in 1990. – user1052448 Jun 05 '15 at 14:56
  • @user1052448 If you are consuming a LARGE amount of electricity, which apparently you are, you need to find out where it is going. In my answer I explain how to do that. – Tyler Durden Jun 05 '15 at 16:36
  • My geothermal system is using 90kWh on average per day. – user1052448 Jun 08 '15 at 19:14
  • @user1052448 Maybe ask the manufacturer if that is normal? – Tyler Durden Jun 08 '15 at 19:22
  • They say my unit is working fine. I requested a map of the piping and it shows the piping is only 5' deep. From what I've been reading, it looks like geothermal should be between 7-10 feet, with 10 feet or deeper being preferred. – user1052448 Jun 09 '15 at 00:45
