I have a piece of signed TV artwork that is mounted in cardboard frame aprox 1cm deep, that i want to hang on the wall. I've had a look round and most of the frames i've found aren't deep enough to fit the piece in.
What are my options for framing and hanging thick artwork?
Steve Jackson
  • 3,780
  • 37
beakersoft
  • 299
    Most any frame shop can custom build you exactly what you need. Otherwise, if the issue is that you need depth within the frame, google 'shadow box' – DA01 Jun 06 '11 at 01:18
    @DA01, can you please post this as an answer so it can be voted on and accepted? – Vebjorn Ljosa Jun 06 '11 at 14:51
1cm isn't really "deep" for artwork. You won't find a photograph frame to fit it, but pretty much any frame for a canvas will be deep enough. You should be able to find these in arts / crafts stores that have a lot of frames. Often department stores will have only photo frames, so you'll probably have to look in more specialized shops.
Otherwise, any frame shop will have a ton of frame styles they can custom size for you. This will be a more expensive option, but you can get the artwork installed in the frame you select with very little work on your part.
Scott Saunders
  • 741
I would have a framer build a frame that is essentially a plexiglass case for the work. Usually, the frame is 5 sides of plexiglass that are screwed into the solid backplane from the sides.The work can be mounted on the solid backplane. I would love to include a picture here but can't find any that show the correct side-view detail.
Zippy
  • 585
You probably want a shadow box display case like this website has. I'm sure you could find others on the web that might be closer to what you're looking for.
billoreid
  • 1,058
