I'm trying to fix a rail and bracket type of shelf this one to be precise.
Having a plasterboard wall, I picked self expanding nylon dowels like this.
My problem is, the rail being U shaped, as soon as I screw, the dowel is pulled out from the wall instead of expanding into it, as expected o_O How should I proceed.
Doresoom
  • 15,623
  • 80
  • 118
yota
  • 103
Can you slip a small screwdriver through the slot to hold the expansion piece into place until the screw expands it enough to stay in place on its own?
Otherwise, maybe you can find a small metal spacer to slide on the screw behind the bracket to help hold the expansion piece while you tighten the screw:
(image from TwistedThrottle.com)
A stack of small washers might also work.
Johnny
  • 4,845
  • 35
The best drywall anchors are toggle bolts. Those plastic things are for hanging pictures (if that; throw them away). Use the metal kind if you must.
Mazura
  • 13,357
  • 56
    thx, I used metal ones, and hopefully, the shelf is standing still :)"read head" market them as `vix`. – yota Jul 26 '15 at 13:54
