The water pressure from the shower head in one of my bathrooms is extremely low. The pressure coming out of the faucet of the bath is low as well. It has not always had this low pressure, it has decreased over time.
All other water sources in the house are fine. What are some possible steps for me to take to troubleshoot this problem? What are some possible fixes?
kzh
  • Duplicate: [how can i improve the water pressure in my shower](http://diy.stackexchange.com/questions/404/how-can-i-improve-the-water-pressure-in-my-shower) – Tester101 Jun 28 '11 at 01:30
    This question is different. My water pressure has decreased over time, and I want to know how best to troubleshoot. – kzh Jun 28 '11 at 02:26
Start with the water pressure in general - is the pressure OK when you're filling the tub? How about the sinks?
Assuming the pressure is OK when filling the tub, that means there's probably a blockage, either in the diverter, or in the shower head itself. Try taking the shower head off - how's the flow? Try replacing the shower head - it could be the old one is clogged (you can get a cheap shower head for a few bucks, and if the one you have is decent quality try soaking it in some CLR).
chris
  • 3,271
Usually cases of a slowly decreasing amount of water are that a filter has become clogged. Does your water supply have sand particles coming through? Check the diverter heads for other faucets in the house. Are they getting many small particles trapped in them? Sand in one faucet tells you that all fixtures are getting clogged, some more slowly than others. This sandy junk can come through municipal water systems, or it can come from your own well if you are on one.
If you are getting much of this coming through, you may choose to install a whole house water filter to prevent that.
Whatever you find in those other faucets, if the problem is both the shower head and the tub spout, then the problem is in the fixture itself. Is this one of the new style fixtures that regulates the temperature of the water? I have read that those temperature regulators can sometimes be a problem themselves, improperly shutting down water flow.
If not that, assuming this is a cartridge based fixture, then you will need to pull the cartridge from the faucet. This entails removing the handle, then removing a locking nut that holds it together. Please shut off the water BEFORE you do any of this! The cartridge will come out, although this sometimes takes some amount of persuasion.
You can buy either a complete cartridge replacement from most manufacturers, or just a set of new o-rings etc., to rebuild the cartridge. Large home centers will have an entire wall filled with various such replacements. Bring in the old cartridge if possible to get a match. Knowing what company made your fixture will help.
A possibility is that a piece of rubber from an o-ring or other seal has cracked and become lodged in an orifice inside the cartridge. Look for this, or for other problems when you open up the cartridge.
