Besides closing it very slowly, any good tricks / gadgets that will slow down the door so it doesn't close with a thud?
There are a few things you can do:
Check the hinges and use a level to see that the door is square. A heavy door hung incorrectly can slam heavily. Check this guide at national contractors for how to level a door. Some tips from it: check that the hinges are tight, not too heavily greased, and the same distance from the frame.
Install a closer arm (can be expensive)
(source: keylessaccesslocks.com)
- If the door isn't closing too hard, but makes a fair amount of noise, try putting some small felt pads on the inside of the jamb to soften the closure.
- 1,173
- 2
- 14
- 20
- 2,432
- 8
- 28
- 32
You could also install from 2-> several dampers like these ones depending how heavy the door is or how well you want to dampen it - for example you have a heavy draft that SLAMS the door shut several will be recomeneded to adsorb the doors speed. These work well if installed fairly well.
Either into the frame somehow- slighlty countersinking it so it hides nicely, or not- its up to you and your skills.
Or just using a provided housing the will mount flush onto the frame of your door in any position that is best for you.
- 5,859
- 20
- 31
I found the dampers for cabinet doors, but not for a room door. I am looking for options for the bathroom door / bedroom doors. They make a decent amount of noise while closing manually. – Toofan Jul 12 '11 at 23:11
yea- those are the ones-- just use 3 top - center bottom or something that suits your needs. it would be best to have them inserted in the frame- looks better. – Piotr Kula Jul 13 '11 at 07:56
An other couple of possible hardware solutions to look into (exact size & weight of the door will determine if they are appropriate or not)...
Cheaper end of the market, Chain Spring Door Closer:
High end of the market, Concealed (Automatic) Door Closer:
- 1,744
- 12
- 16
1These would do the opposite of what original poster wishes. These are door closers (for fire safety), and these particular types would cause door to accelerate towards the frame. – hazymat Nov 07 '16 at 21:13
