I am wiring a second thermostat right next to the original one. The new needs a C wire. Can I share it from the old one?
Old: 8 wires, used to run heat pump (w/ heating and AC) and backup oil. Now only runs AC from heat pump on occasional summer day.
New: Has 2 wires run to it. Controls instant on hot water heater for radiant system.
The new thermostat says, "WILL NOT OPERATE WITHOUT WIRE TO 'C'". Can I take the C wire from the existing thermostat and bridge it to the new thermostat? Can two thermostats share this C wire?
According to Can I piggyback a thermostat with a C Wire hookup on a furnace? I think the answer is "Yes", but when I try it, the new thermostat does not have power.
mankoff
  • 494
  • The `R` wire going to the new thermostat, does it come from the same place as the `C` wire on the old thermostat? Or is there an `R` wire from the heat pump to thermostat 1, and an `R` wire from the boiler to thermostat 2? – Tester101 Nov 04 '15 at 00:45
You can only share the C wire, if you're also sharing the R wire. If the R wires come from different equipment, the C wires must also come from the different equipment.
  • Is there any reason I shouldn't also share the `R` wires? Based on https://diy.stackexchange.com/questions/10482/how-can-i-add-a-c-wire-to-my-thermostat I think so, but I wouldn't want one system to start interacting with the other. Just share power. – mankoff Nov 04 '15 at 01:27
  • You should not share the control wiring between separate systems. – Tester101 Nov 04 '15 at 01:32
  • According to graphics in the link I gave above, the loop only closes when `W` is triggered. It seems like if `C` and `R` were each wired to two systems, the circuits would still be incomplete until `W` triggered, and then only the circuit with the `W` would be active... – mankoff Nov 04 '15 at 02:15
  • @mankoff The loop from `R` to `C` does not rely on `W` at all. That's why those two are used to supply constant power to the thermostat. – Tester101 Nov 04 '15 at 02:31
