My bathroom has some water damage from a poorly designed tile job. The window sill is low enough to get wet but is simply tiled rather than a solid shelf. It's also not properly sloped. This has allowed water to leak into the wall and has weakened the backing board to the point that the tiled wall gave in when leaned on.
One builder wouldn't even estimate the cost of the job. Wanted "time and materials" for the repair and a contract to demolish and remodel the bathroom.
I have been burned by "time and materials" jobs before. Yet I understand that it's difficult to evaluate how big the job is when you can't see all the damage.
Here's my question: Am I being unreasonable if I insist that the job be done in three stages that are bid separately?
A bid for the demolition to expose the problem
A bid for the repair rather than any "time and material work"
A bid for the remodel for any upgrades to the bathroom.
I could take competing bids at each stage and be sure of what I'm getting into before agreeing. Builders wouldn't have to agree to any work they haven't had a chance to fully see.
I'd like to know if this kind of plan is unheard of or unreasonable. Is there any good reason to refuse to work this way? An alternative way to structure the job? If there is something I simply don't understand please let me know.
candied_orange
  • 203
    Your concerns seem legit, but I don't see why you'd split the repair and remodel. Once the cavities are open, someone should be able to bid clearly on the whole project, with no surprises. There might be some dispute on whether enough has been opened to ensure no hidden damage, but other than that... – Daniel Griscom Dec 07 '15 at 14:17
  • @DanielGriscom you're correct. What was important to me was a fully bid job what was important to him was not getting surprised. But he had this "turn key" contract for demolition and remodel ready to go and wouldn't change it except under a "time and material" deal. I'm here trying to figure out how to explain what I want better. I want bids. Not estimates. Not hourly rates. Is there anything I have to do besides clearly ask for that? – candied_orange Dec 07 '15 at 14:26
    Well, it's a negotiation process. You have needs, he has needs, and you hope you can find an arrangement that satisfies both sets. If he isn't flexible enough to figure out what he can give you without violating his needs, you may need to figure it out yourself (e.g. "What would need to be done beforehand for you to give me a fixed-price bid"), or move on to another contractor. – Daniel Griscom Dec 07 '15 at 14:52
  • This begs the question of what you're intending to do if you demo the area and find out that the repair and remodel are going to be more than you'd anticipated. Are you just going to leave it demo'd? I guess I don't really see how the outcome is going to be much different than a time and materials bid except that you won't end up paying the "contingencies" padding that goes into all straight-amount bids. I personally wouldn't even bid the demo on anything other than time and materials unless I was on a sub-contract -- I could be held liable for leaving it in an unsafe condition otherwise. – Comintern Dec 07 '15 at 18:48
    @Comintern: Presumably the OP, having been burned by unscrupulous contractors before, is afraid that the contractor will treat a "time and materials" contract as a *carte blanche* to work as slowly as possible and inflate the material costs as much as they can possibly get away with. If they don't expect repeat business from the OP anyway, and aren't too concerned about their reputation, they don't really have much motivation *not* to milk the OP for as much as they can get, which could easily be far more than the padding in a straight-amount bid. – Ilmari Karonen Dec 07 '15 at 19:17
  • @Comitern the point isn't at all whether the job is more than I anticipate. The point is competition. I don't know home construction. I'm a computer programer. Ask me about code. But if I get 3 bids on every part of the job without allowing unbid work to be done on any "surprises" then I can be confident I've got a good deal. Is there no way to do that without making someone liable for "unsafe conditions"? – candied_orange Dec 08 '15 at 03:52
My suggestion should make this a whole lot easier all around. Do the demolition on a DIY basis and clear away all the debris. The demolition phase work requires basic skills and simple tools that are not expensive.
This will open up the structure of the whole room back to framing, subfloor and ceiling joists. I would say that then you would be ready to bring in a contractor to bid on repairs and upgrades to the room and structure. Nothing should be hidden at that point.
As you take on the DIY part of the project you are sure to have some questions about that process. This site can be a big help to get answers to the questions that arise.
Michael Karas
  • 64,093
  • 63
  • 142
    This is a great option if you're planning a full gut. However, if you're just looking to remedy the problem, this might be a bit overkill. – Tester101 Dec 07 '15 at 13:11
    @Tester101 - Well a subset is also completely possible. The demo could be just the area of the shower. – Michael Karas Dec 07 '15 at 13:16
  • I'm hoping that the damage is to one wall under the window. If I leave the tub in place and rip that wall down to the studs would I be ready for repair bids? Or does the tub need to go? – candied_orange Dec 07 '15 at 14:35
    @MichaelKaras That's true, but a DIYer might not know how far to go. The advantage of having an experienced contractor, is that they know when to dig deeper and when to stop. – Tester101 Dec 07 '15 at 14:46
  • If you leave the tub, there's a bunch of floor that could be very compromised. If you need for there to be no surprises, pull the tub. – User95050 Dec 07 '15 at 14:51
    @CandiedOrange It takes a lot of water damage to ruin the tile backer so thoroughly that it collapses when leaned against. I'd be very, very surprised if you could do the necessary repairs with the tub in place, and honestly I would suggest taking it out simply so you can perform a proper inspection. – Adam Davis Dec 07 '15 at 16:15
    @CandiedOrange I'm not an expert by any means but I agree with Adam Davis, the symptoms you've described sound like the wall is not in very good shape. If you have a second bathroom to use in the meantime, doing the demo yourself would be slower but you'd learn more about what's going on in the wall, which could help you solicit more accurate bids. But if it's your only bathroom, you don't want it out of commission longer than absolutely necessary. – Dan C Dec 07 '15 at 18:32
  • Downvoting as it appears the OP wants the entire job completed by a professional in a professional manner but without getting burned by a T&M contract. The is no mention that they want to "do it themselves" and have expressed concern in comments of doing just that. – Damon Dec 09 '15 at 15:23
  • @Damon - I made a suggestion as to how I saw it could ease the process. In no way am I saying that they have to go that way. I would suggest that there are many instances on this site where alternate ideas posted in answers bring good suggestions to the original poster and provide useful related information to other readers that come here. – Michael Karas Dec 09 '15 at 22:13
  • @MichaelKaras Just figured I'd mention the reason behind my down vote. It is a good idea in general; just felt it did not give any insight to the original question at all. No hard feelings! – Damon Dec 09 '15 at 23:29
Reasonable, except to say that I personally wouldn't be willing to bid the remodel until the repair was done. (Assuming repair by others.)
For permit reasons, you wouldn't close in the repairs, so be sure to move that to the remodel phase.
One disadvantage to this plan is that you're not building a relationship with any one contractor... that might or might not be important to you, but as a broad generalization, I'd say contractors take larger jobs more seriously and shy away from customers that make them nervous.
One last note, probably obvious, but... this will take much longer.
User95050
  • 896
These jobs are tricky to bid. We have an "alternative structure" as you put it. The way we work them is usually this
First, we bid the known scope items. This could be painting, plumbing, electrical, flooring, etc. This is the stuff that will happen regardless of damage.
Next, we bid known repairs and we make a guess as to the extent of the scope if we cannot see all the damage and set a price based on a written set scope of the unseen repairs.
Then, we add a guessed amount for assumed repairs that we are almost sure we will need to complete. These are line items usually are T&M items with a not-to-exceed price without approval. The line item might have a price of say $350, but the detail reads something like "the amount is estimated. Actual repairs will be completed at a price of $xx/hr plus materials. Amount not to exceed $350 without approval" Sometimes these items are not completed for a discount to the owner. Other times things are worse than expected and completed for an APPROVED increase in cost via a change order.
Then just to top things off, we usually add a verbal disclosure of some other repairs that we can think of due to possible damage, but do not show enough evidence of and therefore do not bid it upfront.
Finally, there are the variables we could not see and those we effectively either complete at a T&M price with a verbal estimate of the repairs (trust is usually high on our jobs) or we submit contractual price for the work for those variables via a change order before the repairs are completed and only continue when the change order is approved.
Using this process, we minimize the variables, set well defined expectations of what cost are set and what cost are variable, and finally we put the decision making power in the hands of the client on the variables of the project BEFORE they end up with an unexpectedly high bill.
Let us not forget that verbal estimates are just as binding as written ones so in those rare cases where things need to move on NOW, we work through options, give a verbal estimate, and get approval to proceed and then document the verbal estimate on the back end with a change order.
Damon
  • 1,291
