I'm planning a few upgrades to the wiring in my condo that will require filing plans with the city. It would make my life a lot easier if I had the existing electrical plans (and probably other systems, too). The condo is new construction and I bought it from the builder.
Is it customary for the builder to provide copies of the plans if requested?
Aarthi
  • 1,143
JayL
  • 3,388
  • In the UK you can view plans at the building-reg if they have been submited in the past, but not copy them. It may be your home, but the plans are considered to be copy-right of the person that submited them! – Walker Aug 02 '11 at 11:43
  • I talked to the city building department and they said I could come view the plans... when the whole tract is completed. I will see if I can get them directly from the builder in the meanwhile. – JayL Aug 05 '11 at 04:34
  • @Walker none of the plans I have ever seen for UK domestic building work have had any real information on the wiring. – Peter Green Jan 22 '16 at 17:04
I think it's common in most places for the local government (town/city hall) to have the plans on file. Keep in mind though that sometimes work is done without plans or permits, so use the plans as a guide not an exact map.
Comment converted to answer
  • It's also possible that the plans were not followed exactly - for example, a light circuit to be attached to the nearest outlet because the run was shorter/easier. – gregmac Oct 13 '11 at 22:09
On the west coast of Canada (at least) it is rare for there to exist either planned or as-built plans for electrical (, plumbing, or HVAC) for residential homes (whether single or multi-dwelling buildings).
Floorplans, elevation drawings, and lot plans are required by most municipalities to be submitted to the public record.
alx9r
  • 1,325
