Can someone tell me what sort of hinge this is?
Suspect Hinge
All the cabinet hinges I can find are 180deg+ when open, whereas this is only 90deg.
They are on a set of built-in wardrobes that were here when we moved into our house. Unfortunately, one of the doors had a dirty great mirror stuck on it which is slowly killing the hinges. That door currently has only three out of five hinges actually connected - the others have broken and need replacing before the door drops off on my wife's foot.
Looking for somewhere I can source these in the UK.
SiHa
  • 2,738
  • Can you post what the text in the hinge body is? – Michael Karas Jan 03 '16 at 21:21
  • @MichaelKaras Heh. Didn't think of actually looking at that. It's **GRASS US. PAT. No: RE 34.995**. So it's made by GRASS Inc. I've found a document that mentions this number in connection with US Pat #5,604,956, but doesn't appear to show this type (where the baseplate mounts on the face) – SiHa Jan 03 '16 at 21:32
  • If hinges are breaking, perhaps a heavier-duty hinge would be appropriate? – Technophile Jan 04 '16 at 00:04
  • @Technophile: I agree that heavier-duty hinges would be a better option, but unfortunately I don't have too many choices here. That said, they have lasted the ten years we've been in the house and probably ten more before. The four other doors (without a mirror on them) are also fine, so the situation is not that bad. I do have a Forstner bit though, and will be adding extra hinges to take the increased load. – SiHa Jan 04 '16 at 08:05
  • Google for "face frame hinge UK". Note examples like ["Blum 120"](http://www.trade-hinges.co.uk/blum-120-face-frame-hinge-212-p.asp) – RedGrittyBrick Jan 04 '16 at 10:13
  • Thanks - that was the phrase I was missing - "Face Frame Hinge". – SiHa Jan 04 '16 at 10:17
From what I can tell these appear to be hinges made by GRASS. A look at an online retailer seems to point to these hinges:
http://www.hardwaresource.com/hinges/cabinet-hinges/blum-european-hinges-grass-european-hinges/grass-european-hinges/grass-830-and-831-hinges
However the above appear to be obsolete and they recommend replacing with these hinges:
http://www.hardwaresource.com/index.php?l=product_detail&p=3987
These appear to require two separate order parts.
Michael Karas
  • 64,093
  • 63
  • 142
  • These style hinges often are stocked as two separate parts.The cabinet hardware has multiple ways of attaching, the above piece sets in a Forstner bit produced pocket in the door and will have mechanisms for 90, 135, 180 degree opening, etc.. It's mix and match to get the desired end result. – Fiasco Labs Jan 03 '16 at 21:49
  • Also, these hinges are often referred to as Blum or Compact European Style cabinet hinges. Blum and Grass are common manufacturers. – Fiasco Labs Jan 03 '16 at 21:57
This looks like the hinge in your photo: Grass hinge .It is labeled as a #830 or 831.
ojait
  • 10,949
