Pretty straight-forward. I thought it was absolutely normal and acceptable to use a power drill, with the appropriate bit(s), to drive a screw. However, there seem to be various opinions on the matter. Minus the possibility of laziness, should one only drive a screw with a screwdriver, or is a power drill or impact driver equally matched (and will they not be damaged)?
Yochanan Michael
  • 111
    http://diy.stackexchange.com/questions/21201/when-would-one-use-an-impact-driver-versus-a-regular-drill – Niall C. Jan 11 '16 at 16:35
    Only with a screwdriver? I'd sure hope not. Typically anything small, delicate, or just the occasional screw around the house that doesn't require pulling out the drill is fine with a screwdriver. If it's a large job or you need more power, pull out the power tools. – TFK Jan 11 '16 at 16:42
  • TFK, thanks. Just to clarify. Clearly if I'm driving a screw or a few its a screwdriver, but I've used the power drill for say, driving 20 long screws for a project. Is that acceptable for the tool in that it won't hurt it? Of course, I'm driving very slowly and with patience, but compared to hand driving this can really save a mass of time. – Yochanan Michael Jan 11 '16 at 17:01
The main difference to pay attention to is a drill vs. a driver.
At the core, they are essentially the same in that they turn a bit.
A driver, however, also has a clutch. That's the key difference. With a drill, you want continuous power on the drill bit. However, with a driver, you want continuous power up to a point at which point you want to stop the power to avoid stripping the screw, over-driving or breaking the screw.
You can drive screws with a drill, you just have to be more careful to avoid the problems listed. And while you could drill a hole with a driver, I wouldn't advise it, as the clutch would make it a pain as it would slip as you go.
Ideally, you have both...for no other reason than you can keep the drill bit in the drill, and the driver bit in the driver, and not have to constantly swap bits as you drill pilot holes and add screws right behind it.
As for a "regular" driver vs. an impact driver, you use the latter when you need high-torque. A typical example would be construction screws where you may be screwing through 4x4 timber and the like.
DA01
  • 24,235
  • 27
  • 76
  • 146
The terms are all a bit muddled these days. But there's cordless/corded screw drivers, drills and impact drivers.
Impact Drivers
Impact drivers have a rotating hammering mechanism that can deliver momentary instantaneous impacts of torque to the workpiece, each larger than the recoil that you feel in your hand. They are appropriate for heavy duty tasks, often things with stainless steel hex bolt heads (though that is arbitrary). Impact drivers have a single gearing usually, and are relatively compact, sporting a quick release hex chuck. Be careful to use only high quality or impact-grade bits in an impact driver. Impact drivers can shatter cheap Chinese pot-metal bits.
Power Drills
Drills lack the hammering mechanism, but have multiple gearings and an infinitely adjustable Jacob's chuck to accept any size bit up to the drill's limit (often 3/8 to 1/2 inch). Drills often included several steps of torque limiting (for driving screws and bolts) and an unlimited torque setting for drilling holes through tough material. A good drill is strong enough to break your wrist if it gets away from you, so apply enormous pressure when using on tough materials. The nicer ones have a screw-on side handle to help manage this. Applying tremendous downforce is also useful when driving screws that are already stripped, or which otherwise want to pop the driver bit out.
Cordless Screw Driver
Cordless screw drivers are generally inferior junk, but could be the right tool if you have an incredibly tight budget and no need to drill holes. They usually have a hex chuck, very low torque, low speed, are small, and cheap to replace.
Everyone needs a good impact driver and trusty cordless drill (or two). Cordless screw drivers are a big step down.
Miles
  • 103
I use a power screw driver that is specifically designed for driving screws. It has the motor geared down to a slower speed than a normal electric drill so that it can deliver a lot more torque to the screw.
It also has a clutch mechanism that allows a depth stopper to be attached and cuts off the drive to the bit when the depth is reached....really handy for driving screws into drywall.
Michael Karas
  • 64,093
  • 63
  • 142
    Sheetrock drywall screwdrivers actually spin faster than a drill. They also have built-in countersinks and clutches so the screw ends up at the same depth every time with the highest possible productivity. – gbronner Jan 11 '16 at 17:45
  • @gbronner - You are basically repeating what I I already included in my posting. – Michael Karas Jan 11 '16 at 18:56
    You say that the motor is "geared down to a slower speed". My drywall screwdriver is actually geared up to spin faster, and delivers less torque and avoids snapping the screw head off. – gbronner Jan 11 '16 at 19:24
