I'm planning a chimney demo and planning to hang plastic from floor to ceiling to section where I'm working from the rest of the house. What millimeter thick plastic would be best? I want something thick enough to work but not so heavy I can't tape it up with 2 inch blue painters tape.
3Your next question will be, "Do I skim coat over paint damage on ceiling before repainting?" – DMoore Feb 01 '16 at 15:45
I can comment, from tons of experience, that trying to secure the plastic with blue painters tape is highly likely to lead to a great disappointment in performance. Taping up even the thinnest plastic sheeting is so easily torn down by any pulls and tugs on the plastic. Heavier plastic is even worse.
My recommendation, if you have to use tape, is to use something a lot more aggressive such as Gorilla Tape.
Even better is to drape the top edge of the plastic over a thin board strip such as a 1x2 and prop that up against the ceiling with additional 1x2s that are cut to the proper length to wedge in from floor to ceiling. Then run painters tape along the edge to seal the plastic to the ceiling if needed.
Note that professionals use a product that has adjustable spring loaded posts to hold up plastic in the same manner that I described with the 1x2s above. One such system is described here.
- 64,093
- 7
- 63
- 142
1I've never seen such a system - thanks for explaining it. Sounds like it would work great, and probably cheaper than buying rolls of tape which seem to get more expensive all the time. – JPhi1618 Feb 01 '16 at 15:20
That Amazon link takes me to a 404 page. Could you double-check it? Thanks! – Niall C. Feb 01 '16 at 15:38
I re-did the link to the product manufacturers web site. Note I am not endorsing that particular product but I have seen these used in many places. For example the painters that come in to re-do walls at work come in with several sets of these poles. – Michael Karas Feb 01 '16 at 15:47
I'd be a little cautious about using a really heavy duty tape. When my parents had their kitchen remodeled - to include ripping out old lathwork plaster - plastic curtains were hung to slow the spread of dust. A week or two into the project one of them came down, having peeled some paint off the old plaster in the process. – Dan Is Fiddling By Firelight Feb 01 '16 at 16:44
2@DanNeely - That is the reason to use a dust containment system that includes the nice spring loaded poles. – Michael Karas Feb 01 '16 at 17:30
@JPhi1618 - You can buy two rolls of 2" *painter's* blue tape *OR* one *reusable and multipurpose* pole for ~$20. – Mazura Feb 01 '16 at 20:12
OP here. If I use 2 inch painters tape on less than 1 mil thick plastic hanging no more than 10 feet, is that really not going to hold? It will be just me working, probably 3 days at most. – user20127 Feb 01 '16 at 20:53
3@JPhi1618 - It will hold, probably, but it will most likely periodically start falling down also. Keep in mind Dmoore's comment was not made in jest. You need most of the stuff on this list at the end of [my answer here](http://diy.stackexchange.com/questions/49415/tools-necessary-for-an-efficient-demo), and some plywood to cover the floor. I'll have to add, I question your ability to [safely remove a chimney](http://diy.stackexchange.com/questions/52548/how-would-one-extract-a-brick-chimney-embedded-in-the-middle-of-a-house) if you have to ask how to hang a tarp. – Mazura Feb 01 '16 at 22:23
Contractors at my house have been using a nice type of tape for poly and builder board. I think it's 4" vinyl tape but I'm not positive. It almost seems stretchy – Joe Phillips Feb 29 '20 at 22:07
Any thickness of plastic will stop dust from going through it. The only reason to use thicker plastic as opposed to thinner is that the thicker plastic holds up a little better to punctures and tears (which can then let some dust through). If it's far enough away from your work area that you aren't worried about debris falling against it, you can go as thin as you're comfortable with and tape it. If you can't avoid debris falling against it, go with heavier plastic (or preferably a plastic tarp) and use something more substantial to secure it.
- 6,905
- 1
- 15
- 22
We use pre-taped painter's plastic sheeting all the time for dust management. It comes on a dispenser roll with a built in cutter (like cling film) and tape on one edge. Simply stick the tape to the ceiling (or wherever) and then pull down the folded thin polythene sheet (we use a 10 foot or 3m version).
The polythene is very light so you should put it out of the workspace (better to work anyway) and place something on the bottom edge as pressure (hot/ cool air/doors opening etc. will billow the plastic).
It's brilliant for covering up kitchens etc. just tape it to the cornice/coving etc. near the ceiling and then drape it over the whole thing down to the floor.
Never had a problem with it pulling paint but then we have a lot of wooden ceilings here so it's not very often an issue...
p.s. the film is so thin it seems to hold the dust via static so the clean up is marvellously easy.
- 3,274
- 11
- 18
