We moved into our new home to find that there were some cracks in the shower floor. Even worse though, was that we didn't even see them for the first couple weeks because they had been covered up with some stick-on leaves for traction. It's a textured shower base, but I never thought much of it as some people prefer more traction. However, they started to peel up and we found their attempts are patching the cracks underneath. They'd used some sort of caulking and then a piece of white sticky tape in multiple locations. I just figured that it had to be leaking as this solution was peeling up as well, but this shower is on a slab and we never saw (couldn't see) any leakage ourselves.
I attempted my own patches and we haven't had anything show up still, until the other day - we had a river flowing out of the back of our shower wall under the baseboards. So I've since removed all of the leaves that were left to start fresh and attempted to repatch. Now there is a (new) hole though that was underneath a leaf. Either we just punched it in recently or the leaf was working as a patch of it's own. Regardless, I know that this is the main leakage because it's more of a hole than a crack, about the size of a marble, and I also noticed for the first time that the water in this area doesn't drain down to the drain, it actually puddles up right at this hole.. so it's found a new drain.
Shower base
Our corner shower is about 2'-6" square with a rounded front and door on it. The drain is in the back corner. As depicted in the image, the blue spot is about where/how the water puddles up in the base and in about the middle of the large spot on the right side of it is where the hole is at. I can patch the hole as much as I want, I know, but this drainage issue will always force it's way through any patch I'd believe, or just sit there in the shower. I know what needs to be done with this base (scrap it and start new), but we'd have to replace the entire shower and I don't want this one hole to be the direct cause of that just yet. So my guess is, is there any sort of compound that I could apply to the base to basically almost create a new slope? Or is there any solution, other than scrapping the shower, to this problem?
TFK
  • 3,714
  • 44
There are options available:
  1. Use a DIY repair kit
  2. Hire a local company that specializes in this type of repair
  3. Replace the shower
The first option would be the cheapest. You would need to know the type of material that the shower pan is made of and then search on line for something like ABS shower pan crack repair kit. This solution does not address the reason why the cracks developed and therefore should be considered a short term fix.
A more long term fix would be the second option. In these types of repairs, the company may drill additional holes though the bottom of the shower pan and install a expanding foam. This would provide support under the shower in order to prevent the cracks from reforming after the repair. They will then clean the shower pan and install a new membrane layer to the entire shower pan using waterproof glue/sealant. The cost would depend on who is available in your area.
Here's an example of a company that does this type of repair: Surface Doctors (I have never used them, this is only an example I found online).
The third option would provide the longest term fix but will most likely be the most costly as well.
Factors you might want to consider when deciding what to do:
  • Where is the shower located?
  • Is it located on slab-on-grade or above grade in a wood frame construction?
  • What damage may be caused if the leak returns, will it rot the structure of the building?
  • Do you ever plan to renovate the bathroom?
Thinking about questions like the above may help in making your decision.
pdd
  • 5,404
    It cracks because the manufacturer decided that it should be a 'soft' base (basically sponge on the inside for comfort when you step on it) but with a thin plastic covering. The sponge bends but the plastic doesn't. -- That 'membrane layer' is basically what I want to do myself. Is there something like this that I could use? --- The shower is on our first floor on a slab (it was an addition at some point) but our plans are to renovate, just not this soon. That's why I'm hoping not to replace it just yet. – TFK Feb 09 '16 at 23:25
    I can't comment as to why your's has cracked; it could be a bad product, or a bad installation. As for the membrane layer, you'll need to search for what's available online or in your area. Different repair kits will come with different size patches. Shopping assistance is off topic, and I've never done this type of repair myself, however with the above information you should be able to source out something that will address your issue. – pdd Feb 10 '16 at 00:38
This type of shower should not have bounce to it even it has foam underneath to give it a softer touch. The showers are more often supposed to be installed with a heavy layer of thinset underneath to stabilize the pan and to build up any voids. Some showers are a little softer than others but they don't bounce or flex... or they crack and break.
At this point you are asking us internetters what you should do. You are trying to repair it, you are thinking about products and so on. Well you can fix the crack with repair kits. However you cannot fix the flex that is causing the crack. So your repair kit will work until it dries out fully looses its flexibility and then you stand on the area again and it breaks. Maybe you notice a tiny rip... maybe you don't.
Use your resources better - your time and money. The base has to go - for sure. Not only will it be a lot less time to put a new base in but the big issue is the potential damage you are doing to the rest of your house. Water can slowly screw crap up and you don't want a small leak in places you can't see.
To answer your question - you only need enough slope for water to drain. I suggest that you give up on the pan repair and post another question around how you can get that pan out or alternatives for your situation.
DMoore
  • 47,764
  • 190
You could try this stuff, it's made for spas: ABS Repair Kit.
I'm a surfer, we use some super sticky "grip tape" type material that bonds directly to the surfboard surface to provide traction. It comes in all shapes and sizes including large patches. It sticks like hell to both fiberglass and epoxy boards and is waterproof.
It might be worth a try for temporary use, as you just need to get by until your planned remodel. It sure would save you some $$ if it worked, compared to other options. Many surfers use this to seal and cover dings to the deck of their boards. large deck patch
Jimmy Fix-it
  • 35,093
  • 55
  • Thanks, I found some stuff kind of like this that I'm going to try first and also try to coat over it all with the above answer from pdd. Although it is all temporary, but hopefully it holds. – TFK Feb 11 '16 at 19:54
