Does it hurt if I use pipe dope on water lines connecting a faucet in a vanity?
Asked
Active
Viewed 3,415 times
While is does not address the "safe" aspect, the following Q/A point out many relevant points on dope and when it is appropriate: http://diy.stackexchange.com/questions/21117/when-should-pipe-dope-vs-thread-tape-be-used. I personally know of no reason why pipe dope can't be used for a vanity - but I've only used tape or just relied of the fittings without. – Nicholas Pappas Apr 06 '16 at 22:04
Pipe dope is for lubrication, rather than sealing, but here's one hypothetical drawback: pipe dope could conseal a flaw in the connection. It would be better to know that the connection was poor before finding out by having the pipe dope fail a week later. With a finely threaded connection I think that the sealing capacity could become prominent, leading to the possibility of a cover-up. – Ben Welborn Apr 07 '16 at 17:19
no - pipe dope can pretty much be used everywhere. its not necessary though on anything but a thread to thread seal. most vanities nowadays use flexible supply lines that have compression type fittings at either end with a rubber seal in them. its not necessary on that connection at all.
personal privacy advocate
- 4,730
- 1
- 11
- 17
