I'm going to install a central vacuum system and it would be easiest and most convenient to run the pipe out the side of the garage, run along the exterior side of the house, and then directly through the side of the house to service two bedrooms on the lowest floor.
That side of the house is a 6 foot alley between 2 houses, and the alley is completely sealed off and unused by people in either residence. So, there would be no aesthetic impact to the neighbor whatsoever. Indeed, both houses already have a lot of electrical conduit, network and coax cables mounted externally on the sides of the house in that alley.
This house is in Southern California, so condensation should not be an issue and in any event, the pipe could be wrapped if necessary.
More generally, what building codes govern? This is LA County, California.
bobfandango
  • 1,401
Central vacuum pipe is thin-walled, so be sure to protect it from impact by kids, trash bins, etc. Direct sunlight will exacerbate this over time. Consider painting it to prevent UV damage.
Otherwise, I can think of no concerns aside from the aesthetic implications.
  • Thanks for the answer.. I intend to use schedule 40 PVC instead of standard tubing. That should eliminate any impact concern, and schedule 40 is much much cheaper. Now, I'm pretty sure that is not to code, but I have neighbors who had systems installed for them, schedule 40 was used, and it passed inspection. At any rate, do you know if code with allow for external routing this way? What are the governing codes? – bobfandango Jun 30 '16 at 20:53
    I can't imagine there being any, code in general is for safety and security. As long as the penetrations are sealed correctly with a flame retardant spray or caulk, the only potential problems I can think of are municipal by-law based (sound, aesthetics). – Chris Jul 01 '16 at 12:36
