I just poured my very first concrete project over the weekend and made what I think is a rookie mistake. Somehow I have ghosting from the metal wire that I used as reinforcement.
As you can see here:
My question is, can I cover this up with a feather coat cement mix? Home Depot sells a version called feather finish.
Would this cover it up or would the ghosting still show through? Sorry if this is a novice question :/
Update: I bought the above feather finish finish HD but one or the workers there recommended that I wait until the concrete cures (28 days) before I apply it. Anyone k ow if that's needed?
Andy Grimm
  • Are you going to grind / polish to finish? If you are I don't think I would try putting anything on until you see how it grinds out. – Ed Beal Jul 05 '16 at 14:36
    Or just give it time. You may be seeing variance in moisture due to uneven absorption/evaporation. – isherwood Jul 05 '16 at 16:26
  • Great job! Nice clean edges. I would think you need to wait a bit before this is an actual concern as it still looks "moist". Also those IKEA cabinet walls make me nervous just looking at the picture. – DMoore Jul 05 '16 at 17:36
  • I'm pretty much done with the sanding, it needs to me smoothed out with some 400 grit but then it's done. I read elsewhere that the ghosting never goes away once you see it. – Andy Grimm Jul 05 '16 at 21:52
    It's been 2 months. Any updates? Did the ghosting remain? – DA01 Sep 06 '16 at 05:29
  • Bump. OP, any chance of an update here? it'd be helpful to others finding your question to know what worked---or what didn't, if that's the case. :) – elrobis Mar 27 '17 at 14:25
  • Nothing really fixed it. I tried staining it but the stain didn't react well with the concrete and it turned it purple. I ended up having to sand all of that stain off which may or may not have helped the ghosting, I can't remember but the lines are still there. I've gotten used to them. My issues now is that the kind of concrete I used isn't taking the sealer i bought well and is allowing oil to penetrate and stain the concrete. **Do not** buy the TCC concrete countertop mix from Menards. It has been a huge pain in the arse. I think I am going to go back and feather coat it :/ – Andy Grimm Mar 28 '17 at 15:55
What I would do is put some 2x4" Southern Yellow Pine or even better Oak framing under to brace those flimsy compressed wood cabinets. Otherwise they will bow out over time.
Then I would get an epoxy based coating for concrete. They have these in many types, with or without stone, in all sorts of colorings and will look really good and hold up for years. When done you will have a counter you will be proud of as these epoxy coating look really good.
Usually these epoxy products are two or three parts. Epoxy, hardener, and sometimes a ground stone you apply over the epoxy. The epoxy will vary in price from around $40.00 up to maybe $120.00 a gallon depending on what look you go for but you will probably only need a gallon to cover that concrete counter.
Lifetime of these products vary, but I would expect you to want to remodel the room long before the epoxy needs replacement.
In the future when you make a concrete counter make sure to use a sturdy cabinet(s) as concrete is heavy and modern compressed wood cabinets can't take the weight an old wood or even plywood cabinet could. You should also make sure to tie down the reinforcing mesh so it stays centered in the concrete.
DEH
  • 39
I have a feeling that your ghosting is here to stay... I think the skim coat idea is not good, unlikely it's going to be very durable. I'd consider staining it to a more uniform color and then sealing it.
PaulBinCT2
  • 858
Would a skim coat (specifically, this product) cover it up or would the ghosting still show through?
Ghosting is caused by matrix changes. A skim coat will have a different matrix and should cover it perfectly well. That particular product has good reviews (on Amazon), so I would bet on it.
Ghosting is common with microtoppings, but having a ghost (a slightly different underlying matrix) is not enough to cause this minor problem to get worse. Having major differences like cracks, seams, or significant porosity differences on the table/substrate would create ghosting in a skim coat.
Letting the table dry sounds like sage advice, because the product was made to go on dry surfaces.
Ben Welborn
  • 6,212
  • 48
