15
My attic has tongue and groove planking down as the floor, and I need to do some work up there. I'd like to only remove a couple planks in the middle of the field, rather than pulling up half the floor to get to the point where I need access.
The planks are nailed down (face nailed), and there is not a large enough gap between them to get any type of saw in to cut the tongues (nothing thicker than a razor will fit). The floor will have to be put back together when I'm done, so I don't want to do too much damage when removing the boards.
How can I remove a few boards in the middle of the floor, without damaging any of the planks (too bad)?
ChrisF
  • 16,868
  • 74
If you really want to try to save the plank, BMitch's instructions for removal are spot on but instead of a circular saw, get yourself one of these babies:
The square blade shown here will give you clean end cuts, and for your long run, this blade will be your friend: enter image description here
You'll get very straight, TIGHT cut lines along the seams, be practically invisible when all is back in place.
The Evil Greebo
  • 25,821
  • 124
    I would help if you said what "one of these babies" actually was :) – ChrisF Oct 12 '11 at 20:51
  • Fein calls theirs a [MultiMaster](http://www.themultimastersystem.com/). I have two contractor friends who swear by them. – TomG Oct 12 '11 at 23:47
  • They're usually generically called "Oscillating Multi-Tools" -- Dremel, Bosch, Rockwell, Ryobi, and many others now make them since Fein's patent on the technology has expired. Fein is still the best. Bosch is good. Beware of Dremel's; I've heard the motor burns out quickly under sustained use like you're considering. The expensive part is the replacement bit. Other manufacturers' bits/blades are not compatible with their mounting; Bosch sells converters. Beware of threaded mounting methods. – Karl Katzke Oct 13 '11 at 00:48
  • Personally mine is a Bosch, and I could not be happier with it. – The Evil Greebo Oct 13 '11 at 01:05
    I'll give you the "accept", though it turns out I didn't need to cut anything. Somebody must have done work there before, because the bottom of the groove on a couple planks was already removed. So removing the planks was easy. I did get to buy a new tool, before I made the discovery though! – Tester101 Oct 18 '11 at 13:18
Bite the bullet and sacrifice a single plank, as Steve suggests.
If looks aren't too important or you can't find a replacement board, measure the depth of the planks and set a circular saw to that depth. Get a long straight edge (2x4, extra plank, etc) that you can put on the floor, attached with a couple screws or some very stable weights if you don't want to screw it down. The board should be attached so that the base of the saw runs along it and the blade cuts off the tongue of the adjacent board, freeing the grooves of the board you want to remove. You'll end up with a gap the size of a blade width when you reinstall it.
If looks are important, then cut out one board without damaging the adjacent boards, and get a replacement board. Remove the bottom of the grove on the replacement board so it can be reinstalled from above.
BMitch
  • 42,687
  • 197
Could you drive the nails all the way thru? You might damage the edge of the first board you try to pry out.
aphoria
  • 2,495
  • This might work if the floor was installed with finish nails, but in my situation that is not the case. – Tester101 Oct 12 '11 at 12:37
    If you can get a claw into the wood to pull out the nails, you could potentially pull out the nails of two boards, and then pop them out. If the claw damaged the face, you could then flip them over and re-nail from the back. – DA01 Oct 12 '11 at 17:42
