17
Tightening bolts on the base of a toilet is the one thing about toilet installation that has me the most nervous. They say not to over-tighten, but how tight is too tight before the porcelain is subject to cracking? Do I tighten until I can't tighten anymore? Do I tighten it just before I think it's at its tightest?
oscilatingcretin
  • 5,802
  • 47
  • 96
  • 113
    If the porcelain cracked, it was too tight! – hookenz Jul 08 '13 at 00:18
    Last one I installed used the guideline of "tighten fully by hand, then use the wrench to give it one quarter turn more." Check what your unit's manufacturer suggests. – keshlam May 21 '16 at 00:59
  • While many of the answers boil down to "so it won't leak" I am mostly concerned that small bowl movements will pull the bowl away from the seal. – Sherwood Botsford Feb 22 '20 at 18:30
8 Answers8
20
I start by hand tightening as much as I can, then I tighten a little on each side and check if the toilet moves. If it does then I tighten a bit more, check and repeat until there's no movement. You're trying to avoid bowl movement, so that it doesn't shift or fall over, not to hold the floor up by the toilet bolts.
As tight as you can go will probably snap the porcelain (with a good socket you can torque a nut onto a bolt quite a bit). Until you think it's about to snap is just guessing.
Snug. No movement. Enjoy.
"Too tight" is a sixteenth of a turn past where the porcelain snaps :-)
Stephen
  • 1,925
    The length of your wrench will affect the "feel" of tightness. I have a ratchet with a 2" handle (the most expensive wrench in my toolbox) that I use whenever I don't want to over-tighten a nut (and don't have an explicit torque setting). – kdgregory Oct 15 '11 at 23:11
    Good answer. I basically tightened the nuts to the point where the toilet was level and did not move at all. One last question, though: When I lay my level across the bowl and apply upward pressure on either side of the bowl, the level indicates that there is very slight movement because the bubble moves a tad to the left and right (still within level parameters). However, I can't feel the movement myself. Does this seem fine? – oscilatingcretin Oct 16 '11 at 17:36
    @oscilatingcretin I would personally be ok with it, since the normal operating conditions will have pressure in the downward position, but then I'm more paranoid of over tightening than falling off. – Stephen Oct 17 '11 at 03:08
    Exactly - the point of the bolts is to hold the toilet in place, NOT to create the seal. The seal is created by the wax ring. One quarter turn too far on that bolt and you've ruined a multi hundred dollar toilet. If it doesn't move when you sit on it, it's *tight enough!* – The Evil Greebo Sep 27 '12 at 10:24
    I almost sprayed coffee on my screen when I read "_You're trying to avoid **bowl** movement_". :) – aphoria Sep 27 '12 at 12:40
  • Do **not** move the toilet to see if it's snug. By doing this, you will deform the wax and it probably won't seal well. Never rock the toilet as it is sitting on the seal! –  Jul 07 '13 at 20:35
  • @user13872 Ok, then how *do* you check for proper snugness? – Dan Henderson May 12 '16 at 19:43
    It should be fine to check to see if the toilet moves when it is almost fully tightened. This will help the toilet become fully seated in position. This small level of movement will not deform the wax ring to the point where it will leak. A toilet can be moved quite a bit before the ring fails. You definitely want to make sure that it is completely secure, and tightened down evenly. As long as the pressure is even, you can make it quite tight without breaking the bowl. The trick is to stop when the nuts stop turning with a reasonable amount of force. – Jason Hutchinson May 18 '16 at 20:13
One thing that will help prevent the porcelain cracking is to use a rubber or plastic washer between the head of the bolt and the bowl.
This will take some of the "excess" force by deforming slightly, and by checking for the washer deforming as you tighten you'll have an extra visual check that you've applied enough force.
ChrisF
  • 16,868
  • 74
  • Yeap, not only will it take excess force, it will provide good hold of the toilet so that it doesn't swing. – sharptooth Sep 27 '12 at 10:09
Best practice is to hand tighten nuts, sit on toilet to assist with setting wax ring, tighten nuts to a point of being snug and alternate tightening nuts, then sit back on toilet and if toilet moves, tighten slightly. Check if toilet is level, shim to level, and flush toilet. If leaks, repeat process of sitting on toilet and slightly tighten nuts in an alternating fashion.
user108722
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably [take our tour](//diy.stackexchange.com/tour) so you'll know how best to contribute here. – Daniel Griscom Nov 03 '19 at 11:56
My grandfather was a master plumber for more than 50 years. I asked him one time how tight to make a sink faucet shutoff valve connection. His answer is a classic ... "Tight enough so it don't leak". There is a lot of wisdom in this. The answer for the toilet is the same thing, not too tight but tight enough.
spritle
  • 49
The toilet can wiggle for two reasons: bolts not tight or floor not even (hello old houses!). After tightening the bolts a little bit and making sure you really set that toilet on the ring, see if you need to shim one or two gaps. In my case, i too was worried about cranking down hard on the bolts. The shims stabilized the toilet nic
Rob Latham
  • 175
When you put the toilet in place, with the wax sealing ring between the toilet flange on the floor and the toilet itself, the toilet will be held off the floor a bit by the wax ring. Sit on the toilet backwards (facing the tank - so you can see and reach the nuts) to squish the ring in place sealing the toilet to the flange on the floor. Tighten the nuts on the closet bolts (that attach to the flange) such that the toilet is flat on the floor without rocking.
Tighten it down a bit on one side then the other, then do it again. Rinse and repeat, until the toilet is flat on the floor. If you tighten it too much, you can pull the closet bolt out through the flange, ruining the flange or breaking the porcelain.
DO NOT tighten it as tight as it will go, like you're building something or working on your car - you'll break the flange, chip or crack the porcelain or both.
Most toilets are made of vitreous china. Vitreous china is a glass based enamel coating / glazing technique that is added to porcelain to make it more durable, denser, and shinier. It is also what fine dinner ware, plates, dishes and cups are made of.
stan
Whatever length wrench you're using, choke up on the handle all the way.
"Too tight" begins once you start deforming the washer.
Once you do start to deform the washer, you have to toss the, "hand tighten, then 1/4 turn with a wrench," out the window (not that I've ever found that sentiment to be satisfactory). I've never cracked a toilet by over tightening its bolts. The washers that come with a bolt kit are intentionally flimsy.
If there's a word for the day, it's : snug (for which you either need years of experience, or one cracked toilet, to know when to say when).
My preferred finishing touch is, once it's sung, grout it in place (keeps hair from getting stuck in the grove, and other yuckiness) and then I guarantee, it will not rock. My preferred tool, is my little six inch adjustable wrench. I don't choke up on it, but I know when to say when.
Mazura
  • 13,357
  • 56
You should never grout or silicone your toilet in place. If for some reason you have a leak at the connection between the flange and wax ring it will collect under the bowl and by the time you notice it, it will may have ruined the floor under it not to mention the condensation that is being created in that pocket which you created by sealing it. Also, the mess you will have to clean up when you eventually replace that toilet. I would much rather remove hair and "yuckiness" then grout or silicone with more "yuckiness" attached to the silicone or grout and or run the risk of damaging the floor to remove it... as far as tightening goes, hand tighten, go one full turn with perfered tool, sit on the bowl, slightly lift your left leg and right leg to see if the toilet rocks if it does turn bolts a half turn, rinse repeat till no Rocking occurs, assuming you have a fresh nice flange. 534 Water closets installed. $
