I'm swapping out our original, builder-grade disposal for a new one, and the one I ended up getting and starting to work with was wired with a plug. The original unit was connected to some 3-wire cable that vanishes into a hole in the wall on the back of the cabinet.
I figure the best way to approach this is to add an outlet -- is it as simple as connecting the existing 3 leads to an outlet? Should I use a GFCI? Should the outlet be recessed (if possible) or is it okay to mount it in a box on the back wall of the cabinet? The dishwasher is currently direct-wired as well and I think they're on the same circuit.
Thanks!
UPDATE:
I installed a metal box by screwing it to the back of the cabinet, and the cable is now coming through it. I attached the 3 wires directly to a GFCI switch, but whenever I flip the breaker on and toggle the wall switch to turn the disposal on, the breaker trips. So something's not right. I'm going to switch to a regular outlet and see if that helps.
UPDATE 2:
As requested, here are some pics of the wiring as it is now, pigtailed into an outlet. The GFCI outlet was the same as this except I wired it directly to the cable coming out of the wall, and used the terminals that weren't blocked out by the yellow LOAD sticker.
pigtails
silver side posts"
brass side posts
Bret
    Can you post a photo of how the GFCI switch was wired? – ThreePhaseEel Sep 03 '16 at 19:48
  • Not any more -- I swapped it for a regular outlet and it's still doing the same thing. I'll add a pic of that to the original question in a moment, because it's still tripping whenever I turn the switch on. – Bret Sep 04 '16 at 19:51
Nothing I tried worked, so I called an electrician who came out, and in 30 minutes pulled the cable out, examined it for breaks or accidental punctures, put everything back, and then it "just worked." He swore he didn't do anything to fix it. I suspect a screw I put in had just nicked the insulation or was causing a short in some other way and he thought that might've been possible in a bit of cable he couldn't inspect. Anyway, it's working now and I feel like less of an idiot. :-)
Thanks, all!
Bret
I'm not a code expert, but I don't see why that wouldn't work just fine. Yes, use a GFCI due to the increased likelihood of water exposure (assuming that the breaker isn't already GFCI-protected). A winged remodeler box will work well assuming you steer clear of framing.
    https://diy.stackexchange.com/questions/76161/does-a-garbage-disposal-and-or-dishwasher-need-to-be-on-a-gfci – mfarver Sep 02 '16 at 15:46
