18
I have some decking in my back garden and some of the planks need replacing. However, the screws are difficult to remove.
Some have rusted/weakened sufficiently so that I've managed to remove the screw head entirely when trying to unscrew them while others are just very stubborn and hard to undo.
I've put some WD40 on them and this has helped in some cases, but there are still many that are proving very hard to get out.
The planks will be thrown away so I was considering drilling through the wood around the screw and effectively allowing me to remove the plank and leave the screw behind (possibly in a little plug of wood left behind) but then I'm stuck with still having to get the screw out.
I'll also have to remove the shafts of the screws that have lost their heads but I'm hoping that using pliers will do that.
What would be an effective course of action for dealing with stubborn screws in old decking?
Matt Hogan-Jones
  • 319
    When screws are that deteriorated, or not meant for outdoor use, I end up treating them like nails. A cat's paw or similar fastener puller and yank them out. – BrownRedHawk Oct 24 '16 at 11:43
    @BrownRedHawk My thoughts exactly. If they are rusted all the way down the threads, they should come put pretty easily. If not, you can always buy a pack of drill bits and drill right through them. Just make sure the are made for drilling into metal (most common bits are good for wood and metal) – JimmyJames Oct 24 '16 at 14:06
6 Answers6
22
When the boards having the heads are being discarded, a simple way to remove them is to cut through the screws at the joint between the board.
You can use a reciprocating saw (often called by a brandname, Sawzall) recip saw
or a multitool multi tool
In either case, you need to use a blade intended for cutting metal. Some blades are combination blades that work in wood or metal. Place the blades between the bottom of the decking and the supporting framing and cut just the screw. The small amount of wood taken out will not matter, but lean the blade toward the wood being discarded.
If you can't access the bottom of the deck, you can remove a section of the board to be discarded close to the screw and then cut the screw horizontally.
The stub of the old screw in the framing board will be covered by the new boards.
 Images and links are illustrative only, not an endorsement of goods or sources.
bib
  • 33,635
  • 100
  • Cool, I think that's probably the way I'll go - many thanks. I'll start researching multitools. – Matt Hogan-Jones Oct 24 '16 at 12:14
  • +1 on the sawzall. Can also use an impact driver but it will snap the head Can also use a long crowbar/cold chisel with a mini sledge hammer to shear screws off/pull through the wood. Consider stainless 304/316 Robertson screws for next deck install and predrill holes before installing – binaryOps20 Dec 09 '20 at 10:19
@Bib is absolutely correct in the answer above, but in the grand tradition of skinning a cat multiple ways, here's an alternate approach. I think this would be faster than an oscillating tool and easier than a sawzall. (Though both are great tools to have -- don't let me discourage you there.)
Given that you're not trying to save the deck boards, I'd use a circular saw to rough cut them first, then use a sledge hammer to knock them off the screws. Anything that is awkward for the sledge can usually be removed with a 2' pry bar. If any screws remain, first hit them sideways with a hammer to see if you can break them; otherwise, twist them out with vise grips. (This assumes that you're taking out a large percentage of deck boards... if you're just plucking a few strategically, this advice doesn't apply. However, if a few of your deck boards are bad, it's probably not long before all of your deck boards are bad, so doing everything at once might work well.)
Cutting strategy: if your deck is nearly ground level, then just run the circular saw between each joist. This is a lot like cutting the tree limb that you're sitting on, so care is required as you get to the edge. If the deck is a little higher, (so hard to access from the ground), cut so that you've got walkways of deck boards that bridge two joists. The pattern would look like this: enter image description here
Again, use caution, as you're relying on less and less structure to keep you from tumbling.
Aloysius Defenestrate
  • 20,214
  • 54
    Interesting idea - right now I only want to replace a couple of boards that aren't next to each other, as they were already damaged when we bought the property and it's the damaged areas that have had water penetration and have decayed noticeably. However, replacing all of the will probably be a job for spring, so I will keep this in mind. – Matt Hogan-Jones Oct 24 '16 at 14:03
    Sledge hammer / pry-bar, +1. Trying to cut the screws, you'll mess up the joists. Grind off what's left of them later. OP should've asked how to remove the boards, not the screws. Remove the ones you can; ignore the rest as if they're glue. – Mazura Oct 24 '16 at 20:30
If your just replacing a few boards and you can see the screws clearly, I have had pretty good luck using a coring bit. They can be a little hard to find without pilot bit, but they work very well. You can also find a hole saw without a pilot and it would work well.
You simply put the hole around the screw, the large plank comes off, and your left with a little wheel of wood that is screwed in.
You can then usually just turn the wooden "wheel" and the screw will come right out. Or you could use vise grips. If none of that works then you can just cut the screw, and hammer the remainder into the joists.
coteyr
  • 656
  • Would a Coring Bit be the same as a hole saw? – Criggie Oct 26 '16 at 08:31
    They are very similar. A coring bit is usually "deeper" allowing you to drill through, say a foot of wood, where a hole saw is may a few inches. Both would work fine in this case, so long as they are meant to be used on wood. A lot of coring bits are meant for concrete, etc. – coteyr Oct 26 '16 at 08:43
When the plank is to be replaced you can cut the plank either side of the joist (I drilled a hole to start then a power jigsaw to cut). Then split the small remaining bit of plank along its grain with an old chisel (not a good one, please!) adjacent to the screw. That will leave a rusty screw protruding out of the joist.
I have always found that if you grab such a protruding screw head with a self-grip wrench and rotate it anticlockwise it will either unstick or shear off. If it shears off below the top of the joist all is as good as it could be. Otherwise you may have to cut, file or grind off the remaining protruding bit with a hacksaw, hand file or various possible power tools. Whichever, it's a lot easier with the plank gone!
I'd probably try giving the stuck screws a good whack with an impact driver before attacking the plank, if I had an impact driver available. Quick, and nothing lost if it fails.
nigel222
  • 778
  • That's a good idea - cutting it either side of the joist may well be easier than trying to drill a circle of connecting holes around each screw. – Matt Hogan-Jones Oct 24 '16 at 15:10
My screws had rusted in after a decade outside so I actually found the easiest way was a mallet and crowbar to lift the decking planks up.
If you are keeping the decking this works well, if you are not, once you have one out you could saw up the decking, makes it easier to transport to the tip as well.
indofraiser
  • 113
  • The original question was about removing **screws**; this wouldn't work. – Daniel Griscom Oct 25 '16 at 10:50
    Actually it does, when I did it, it removed the screws by lifting the planks. The user states they are not keeping the planks, the screws are being removed from, so I imagine they will need to lift them up at some stage. – indofraiser Oct 25 '16 at 13:05
  • You said "nails" in your answer, and "screws" in your comment; which was it? (Pulling screws out of joists without twisting them is a good way of leaving significant holes in the joists.) – Daniel Griscom Oct 25 '16 at 17:15
Same issue. The recip saw is a bad idea. They take forever to slice through the screws and usually the screws are sandwiching the boads to the joists pretty tight so it doesn't work even with metal cutting blades. If you crowbar or deck-wrecker them you're going to be replacing a few joists so that doesn't really work either. I'm going to slice them with a circular saw and split the 2 inch strips with a chisel and call it a day. Someone posted a video of grinding the screw heads out. Takes forever, and the grind wheel seems to melt the screw heads. I have ground down to 1/2 inch and screw head is still there. So That doesn't work. Circular, chisel, discard, put down new boards.
