Today, I found my home has a gutter install as below:
My question is:
- The hanger screw has penetrate through the metal drip edge and gutter the fascia (cover), is it right? I am thinking it should go below the metal drip edge to avid damage meta drip edge.
- The gutter installed almost above the fascia board, reach to the meta drip edge already. I am thinking water will leak out to fascia board later if gutter has been clogged.
- The fascia has covered almost the whole fascia board, Is it good for fascia board protection? or if it should run below the gutter hanger screw?
Is it right now? if not, how should I fix it?
