I am planning to build a "floating" platform that needs to be able to hold at least 200kg (440 lb), the problem is, I can't attach it to three walls, as there is an exit on the third wall. My question is: is this possible, or would it have to have a pillar on the unsupported corner? Here is a birds eye view with dimensionsDrawing badly scanned in Thanks, Ben
EDIT: It's basically a floating bed, strain wise.
Wouldn't need to have a pillar. Would need at least a diagonal brace securely mounted to the wall framing. Unless, that is, you can build a boxed platform rigid enough to carry that stress without flex.
I'd use 3-5 heavy duty brackets like this.You'd barely be able to see them under your platform, leaving it with a floating appearance. Leave the end one 20-40cm from the end to help hide it visually.
I've built several such surfaces with good results using 2-1/2" lag screws. The brackets should ideally reach about 2/3 the way to the front or could be extended with structural top rails.
This question comes along regularly in various forms. Here are a few.
How can I support a desk without legs or brackets
How can I mount a desk on a wall with L-brackets?
How is a floating desk top supported against the wall?
DIY Floating Desk in New Build Home
What is the ideal method of supporting a 27" deep floating desk across 10 feet of wall?
  • Thanks, Do lag screws work in aerated concrete, or would I use some sort of heavy duty wall anchors? Also would [this](https://www.fischer.co.uk/en-gb/products/high-performance-steel-anchors/aircrete-anchor-fpx-i) work? – Landless9913 Mar 13 '18 at 21:47
  • I haven't worked with aerated concrete, but I'd guess that anchor would work fine. You must use some sort of expanding anchor, as concrete screws alone wouldn't have enough bite. – isherwood Mar 14 '18 at 13:11
Anchor that corner to the ceiling with some cable and eye bolts.
Mike
  • 448
