58
In at least two different contexts now (installing shower handrails, installing gate on fence) I've found myself stripping the head of the screw beyond all use. I must be doing something wrong, so what is it?
The screws I'm driving are two or three inches long with a Phillips head. I'm using a cordless drill with a Phillips bit. I find that no matter how hard I push from behind the drill (even with all the body weight I can muster) and no matter what speed I drive at, the drill bit jumps out of the head of the screw. When that happens repeatedly (either because I think I can make it if I just push it harder, or I get frustrated), the head ends up getting stripped and then I've got multiple problems (getting the screw out, replacing it, and getting the replacement in without stripping it) that set the project back. What am I doing wrong?
UPDATE: Thanks to all who contributed to the great answers below! After checking my screws and bits (Phillips, not Pozidriv; right size, not worn), drilling wider pilot holes and then being careful with the speed and torque, I decided I wasn't using the right tool for the job (what's that they say about bad workmen?) and I went and got an impact driver. Then the first few screws went in like magic --- it was incredible! And then it sheared off the heads of the next couple of screws. Grrr! I couldn't manage to get the remnants out, and ended up drilling new holes in which I tried some new store-bought screws --- same result. Double grrr! So I drilled some new holes and tried some hex-head screws, which went in just fine with a socket on my cordless drill. Hurray!
Conclusion: I hate Phillips heads for high-torque situations; I much prefer hex heads. That's how I settled this particular matter, but there are some very important and useful answers below that were not "accepted" that nevertheless may help people in slightly different circumstances.
Paul Price
  • 1,207
  • Related: https://diy.stackexchange.com/a/106688/2815 – RedGrittyBrick Jul 24 '18 at 09:47
    In the fence job were you using "decking screws"? Some of these have a combined phillips/square drive head *and* one driver bit is included in the box of screws. You can drive with either Phillips or square, but the combined does even better. – Jim Stewart Jul 24 '18 at 10:22
    As far as I can tell, the screws and the bit are bona fide Phillips (no square, no Pozi wings). I didn't choose them: they're just the screws that came with the kit I'm installing. The manufacturer seems to think that they're the right screws for the job. – Paul Price Jul 24 '18 at 13:24
  • Go slower? Harder for it to jump out if you slow down at the end. In addition to checking bit size and condition and type as otherwise suggested. – Karthik T Jul 24 '18 at 13:45
    Does your driver have a torque limiter? It's typically a numbered collar that you twist. The top setting is often a graphic of a drill bit. When driving screws, especially Phillips, I use a very low max torque setting. – JimmyJames Jul 24 '18 at 13:53
    Step one of almost any project is throwing away the screws they gave you. – Mazura Jul 24 '18 at 19:16
  • Rule 1 is use the right size bit. Rule 2 is to discard worn bits. – Hot Licks Jul 24 '18 at 22:11
    If I could upvote @Mazura's comment twice, I would. Screws supplied with hardware are invariably the cheapest screws the manufacturer could source. They're usually too blunt to be used in anything other than the softest material without drilling a pilot hole first, and often are made with too soft a material so the head tears up very easily. Dump them and switch to a higher quality screw. – Jules Jul 24 '18 at 22:55
  • Sounds like you are trying to use wood screws in a task where lag screws are commonly used. – Netduke Jul 26 '18 at 15:43
    Shearing off heads is part of the learning curve with impact drivers. But I use imitation(1) Deckmate screws for just about everything and I can't ever recall snapping the head off of one of those. (1. because they stopped making combo square drive and now they're all stupid torx, so now you'd have to switch between P2s, Combo SD, *and* torx all day long if you do renovation. – Mazura Jul 27 '18 at 00:29
  • The bits might have needed re-engineering, but SD were the shit. You *can* use a P2 (Phillips *or* square!) to pull them out or put them in. Good luck using a torx bit for anything other than a torx fastener that's exactly the right size. – Mazura Jul 27 '18 at 00:33
    Once you've stripped the heads, a nice trick to pull them out is to use a **rubber glove or a plastic balloon** to increase the friction. – alseether Jul 30 '18 at 14:08
  • IMHO the production and use of Phillips head screws should frankly be forbidden by the Geneva Convention. There is no reason on earth to ever again use any screw head other than Torx. :/ – fgysin Jun 30 '22 at 14:04
14 Answers14
63
If you're stripping the heads, Phillips head screws probably aren't the right kind for the job. They cam out under excessive torque [1]. And once they do, the bit becomes a grinding tool, chipping away the head. They're good for uses where high torque isn't required. Phillips head screws intended for use where they might require some torque are hardened, which reduces the chipping if they cam out.
The solution is to use the right kind of screw for the job, and to not substitute brute force for proper technique in a demanding situation. Excessive torque shouldn't be required if you don't cut corners on technique. But if a lot of torque is needed, use screws that can handle it.
  • Drill a pilot hole. There are actually different optimum-sized pilot holes recommended for different materials. With soft wood, a precisely sized pilot hole often isn't critical if you are close, but If you are screwing into hardwood or metal, the right size pilot hole is important.
  • Lubricate the threads by rubbing the screw on some candle wax or bar soap (not liquid soap), before you drive it.
  • Don't use a worn driver bit or one that is not the exact size for the head. This is especially important for Phillips head bits because camming out and grinding away the head also grinds away the bit, making it more prone to cam out.
  • In a demanding situation, use hardened screws or a different type of head. For example, square, hex (Allen), or star (Torx) socket heads are common for high-torque applications, or a hex head that you use a socket to turn.
[1] There's a long-running argument on whether cam out was an intentional design objective or just a characteristic of the design. According to Wikipedia: The design is often criticized for its tendency to cam out at lower torque levels than other "cross head" designs. There has long been a popular belief that this was actually a deliberate feature of the design, for the purpose of assembling aluminum aircraft without overtightening the fasteners. Extensive evidence is lacking for this specific narrative, and the feature is not mentioned in the original patents. However, a 1949 refinement to the original design described in US Patent #2,474,994 describes this feature.
fixer1234
  • 6,068
    Yeah, I've come to loathe Phillips head screws. I'm using the screws that came with the kit I'm installing, but after stripping a couple my first thought was to go and get a similar screw with a different head. – Paul Price Jul 24 '18 at 13:38
    Another type of screw head that I see commonly is the triple-square. It looks kind of like a torx. Here's a good page for reference: https://en.wikipedia.org/wiki/List_of_screw_drives – JimmyJames Jul 24 '18 at 13:41
  • After my new impact driver sheared off the heads of a few of Phillips head screws that came with the kit, I bailed on the Phillips head. I managed to find some suitable screws with a hex head, and they went in just fine with a socket attached to my cordless drill. Thanks for the advice! – Paul Price Jul 24 '18 at 20:23
    Once you've used hex/star screws it's really hard to use anything else. – enderland Jul 25 '18 at 00:13
  • Phillips heads were actually designed to cam out. The same factory then changed the heads slightly, to produce Pozidriv, which resisted camming out (or cam outing!) Better, for different applications. Allen and Torx are a lot more positive - even quite rusty ones, but that doesn't help us when we need to remove Phillips headed screws. – Tim Jul 27 '18 at 11:01
    @Tim Phillips wasn't designed to cam out, and Phillips and PoziDriv were produced by different companies. (And, when you say "the same factory", you're suggesting that all the Phillips and Posidriv screws in the world were made in just one factory? That's not remotely plausible.) – David Richerby Jul 27 '18 at 11:22
  • @DavidRicherby - maybe it wasn't designed that way, but that's what happens, hence PoziDriv and all my research says it's the same factory/company. Please enlighten me further. – Tim Jul 27 '18 at 15:00
  • @Tim Phillips was originally [patented in the US](https://patents.google.com/patent/US2046837) by the Phillips Screw Company (not to be confused with Philips with one L, the Dutch electronics company), later the American Screw Company. Posidriv was invented in the UK by GKN ([patent](https://patents.google.com/patent/GB1006509A/en)). – David Richerby Jul 27 '18 at 15:10
  • @DavidRicherby - it would seem that although the patent for PoziDriv was obtained in '62/'63, the originals were manufactured by the American Screw Co. and Phillips in the late '50s, in the States, as an improvement on the slippable Phillips concept. Perhaps no-one bothered to patent it for 10 yrs or so? – Tim Jul 27 '18 at 16:42
    @DavidRicherby, you and Tim are both right. From Wikipedia: The design is often criticized for its tendency to cam out at lower torque levels than other "cross head" designs. There has long been a popular belief that this was actually a deliberate feature of the design, for the purpose of assembling aluminum aircraft without overtightening the fasteners. Extensive evidence is lacking for this specific narrative, and the feature is not mentioned in the original patents. However, a 1949 refinement to the original design described in US Patent #2,474,994 describes this feature. – fixer1234 Jul 27 '18 at 18:27
45
You may be having one or more of the problems as follows:
  1. You are using the wrong size driver bit for the screw type. Make sure the bit fits perfectly in the slot of the screw.
  2. You may be trying to use a driver bit that has its edges rounded off so bad from previous usage that the bit is next to useless.
  3. You may have a really cheap driver bit chosen from a large assortment set. Very often these cheap sets have driver bits that are made of very soft metal and easily strip.
  4. You may not be drilling a proper sized pilot hole for the screw. The pilot hole needs to match the inside diameter of the screw thread so that there is a place for the body of the screw to enter the hole and just allow the screw threads to engage the inside surface of the pilot hole.
  5. You may be using screws of a type incompatible with the materials that you are attempting to screw into. There are specific type screws for wood, sheet steel and aluminum.
  6. You may be neglecting to lubricate the screw before attempting to drive it home. Rubbing the screw threads across a soft bar of bath soap can make all the difference in getting a screw installed. Liquid soap is not generally recommended as it can stain the wood if it runs out on the wood surface.
  7. If you are screwing into a metal piece there is a decided limit of the thickness that a given screw can penetrate even with proper pilot hole and material compatible screws.
Michael Karas
  • 64,093
  • 63
  • 142
    I bought a pack of somewhat good quality Wera bits for my drill/driver and the difference is night and day - using the correct sized bit, they almost never cam out or chew the head whereas cheap bits start off bad and only get worse with each incident. Don't be shy of throwing away a bit that has cammed out one too many times, they're not that expensive and life's too short to ruin a project for a couple of quid. – John U Jul 24 '18 at 10:32
    #8. You could be holding the drill at an angle. Make sure the drill bit is lined up with the screw shaft. – MonkeyZeus Jul 24 '18 at 12:27
    #9. If your drill has settings such as hammer/screw/drill then make sure you are using the "screw" setting. – MonkeyZeus Jul 24 '18 at 12:38
  • #10. If you bought a really cheap box of 2-3 inch screws like on clearance or from the dollar store or something then they are probably made from a very cheap metal. I've never had trouble driving a quality 3 inch screw into a 4x4 post. – MonkeyZeus Jul 24 '18 at 14:23
    #11. **[Is your drill a impact/hammer-only model?](https://hips.hearstapps.com/pop.h-cdn.co/assets/16/03/1280x2083/gallery-1453484981-ridgid.jpg?resize=480:*)** – MonkeyZeus Jul 24 '18 at 14:25
    #12 You have a clutch on your drill/powered screwdriver, but you've set it to too high a torque. – Todd Wilcox Jul 24 '18 at 15:37
    #0 using Phillips in the first place instead of something like a Torx or Robertson. – Dean MacGregor Jul 24 '18 at 15:45
    #4 is the most likely scenario. OP shouldn't need to put all his weight driving a screw with a properly pre-drilled hole (to hole size and depth). Maybe if it was some very hard material but showers and gates, no. If I accidentally use the drill mode instead of the impact on a pre-drilled hole, it just goes in crazy fast and potentially strips at the end, but the screw will bottom out where it needs to be. – jmathew Jul 24 '18 at 18:05
  • Thanks for all these helpful ideas. I considered them, but in the end simply gave up on the Phillips screws. So the fact that this isn't the "accepted" answer simply means it didn't work for me and doesn't mean that someone else won't profit from these very useful considerations. – Paul Price Jul 24 '18 at 20:19
28
Using a drill to drive screws. I used to have the same problem as you, until I switched to using an Impact driver instead.
Drills are designed for drilling holes. They deliver a nice consistent torque. When the resistance of the screw increases this tends to cause camming out.
Impact drivers are designed for driving screws. They deliver a variable torque. When the resistance of the screw increases the variable torque "kicks" the screw round, making camming out less likely. (Not sure I've got the physics of "why" they work better quite right. But I promise you they do.)
AndyT
  • 1,878
  • Check out https://diy.stackexchange.com/a/21215/42053 for your answer as to why they work better when used properly :) – MonkeyZeus Jul 24 '18 at 14:30
    I haven't stripped out one screw since moving to a impact driver. It's like magic, and you can do it with one hand - not much force required. – JPhi1618 Jul 24 '18 at 17:56
    One caveat with an impact driver is that not all screws are designed to take the torque - I've had some wood screws just shear off at the head. The box of screws should indicate whether they are impact-friendly (though I've never had any problem with the standard round-head #2 Phillips screws that come with things like curtain rods, etc.) – Tanaya Jul 24 '18 at 18:55
    I went and got me an impact driver. The first few screws went in like magic, and I was ecstatic. "Where have you been all my life!" Then the heads of the next couple of screws just sheared right off, making the problem even worse. – Paul Price Jul 24 '18 at 20:03
  • @PaulPrice - Guess that's a +1 to Tanaya's comment above yours then! Can't say it's a problem I've had personally, but then I mainly use my impact driver on packs of "proper" screws when assembling stud walls etc. rather than whatever comes with a handrail. – AndyT Jul 25 '18 at 08:13
    I like impact screwdrivers too. My explanation is that it takes some time (not much, but some) for the bit to work its way out of the screw head. The impact driver is just that: a series of impacts with practically no torque at all in between. So the average torque is still significant, while allowing the bit to re-seat. – AaronD Jul 25 '18 at 20:05
25
It could be that the driver you are using is not a Phillips but a Pozidriv or the screws are Pozidriv and the driver is a Phillips.
See https://www.finehomebuilding.com/2015/09/16/what-is-the-difference-screw-bits-phillips-vs-pozidriv
Jim Stewart
  • 20,876
  • +1 9/10 cases in my experience, but I'm in a market with high Pozidriv penetration. – Agent_L Jul 24 '18 at 10:59
  • Almost certainly this. Look at the screw head. Is there a thin "X" overlaid over the plus sign? If so, it's Pozidriv. Look at your driver head. Are there extra "fins" lower down between the four main ones? If so, it's Pozidriv. – Sneftel Jul 24 '18 at 12:06
  • @Sneftel OP haven't stated a location, and I've been told that in USA Pozidriv is unheard of. – Agent_L Jul 24 '18 at 13:18
    @Agent_L Pozidriv screws are unusual in hardware stores (less so in electronics supply houses). But Pozidriv bits are extremely common in driver bit sets. – Sneftel Jul 24 '18 at 13:22
    I appreciate the answer, but as far as I can tell, it's not a Pozidriv screw nor bit. Indeed, this is the USA, and I've never seen a Pozidriv in real life before. – Paul Price Jul 24 '18 at 13:27
    So you mean all of those "cheaply made Phillips-head screws that look a bit funny and *always* strip if you're not super careful" that I've been using are actually supposed to be that way because they're "Pozidriv" screws and need a different driver? Amazing. – aroth Jul 24 '18 at 13:44
    @aroth yeah, Pozidriv is amazing when you use the proper driver. Much more solid feeling and almost never strips. It was designed to be similar to Phillips but to improve on some of its shortcomings. – Muzer Jul 24 '18 at 14:07
    @Agent_L IKEA uses Pozidriv screws exclusively, so that's one place you'll see them in the US. – Tristan Jul 24 '18 at 15:24
    @Agent_L i use them a lot in the US (work in sfh construction) – user87417 Jul 24 '18 at 17:06
  • @Sneftel _"Pozidriv screws are unusual in hardware stores ..."_ - Maybe where you live, but where I'm from Pozidriv screws clearly outnumber Philips screws in hardware stores ;) – marcelm Jul 26 '18 at 21:51
15
A common mistake of inexperienced people is going straight in with a fancy power tool, and never learning the task with hand tools. This deprives you of a lot of tactile-experience knowledge that is essential to success.
If you had used a plain old Philips screwdriver, first you wouldn't chew up the heads. Second, you would quickly discover the core problem: you are asking the screw to perform way beyond its design ability. The material you're screwing into is too hard, or you're drilling too deep, etc. You would take a hard look at the material and pre-drill the hole, and if that is not enough, pre-drill it somewhat larger -- until it is possible to drive the screw with a common screwdriver.
After the first one, you now know which drill size is correct for pre-drilling. So you simply leave that drill in the drill/driver.
What about doing many of them? I grab my speed wrench and bit holder.
enter image description here image source
This give me several things at the same time:
  • speed of work about that of a power tool (I've done a roof with this)
  • precise control not possible with power tools - I set exactly the depth I want
  • no rat-tat-tat camming out the Philips head, when it jumps, just stop
  • extremely accurate torque feedback, so no chance of breaking a screw off
  • the ability to push Quite Hard on the screw head
  • never runs out of batteries
You mentioned you're using a cordless drill. Remember that there's a difference between drilling (torque goes to bit speed) and driving (torque goes to power behind the screwing). If you ever buy a cordless screwdriver, it only does driving.
If you have a more recent model cordless drill, it may have a switch between the two (my Dewalt does) and you'll note the difference immediately, because in driving mode the bit doesn't spin anywhere near as fast.
Impact drivers add vibration to the driving mix. They drive until the bit encounters resistance and then it vibrates the bit to help drive the screw (it makes a loud racket in the process). Do NOT confuse these with hammer drills, as hammer drills are meant to pound drill bits through masonry. Also, be sure any screwdriver bits you use with an impact driver are meant for that purpose (they can shred regular drill bits that aren't hardened against the vibration).
  • I never knew there were drill bits that could be used with the hammer drill - when I used the hammer drill (by mistake) with a philips screw head the result was that the bouncing of the drill resulted in the head jumping out all the time. Do they just have much deeper heads to stop this happening? – UKMonkey Jul 24 '18 at 12:44
    Hammer drills aren't meant for driving screws. Period. Impact drivers are for driving. – Machavity Jul 24 '18 at 12:51
    @UKMonkey - In a hammer drill the hammering is a movement along the axis of the bit, into the wall. It's used for drilling into masonry. In an impact driver has a twisting vibration, i.e. around the axis of the bit. It's used for driving screws. Hammer drill and impact driver are very different things. – AndyT Jul 24 '18 at 13:19
    @Machavity - My cordless drill has about 22 different driving speeds, drill setting and hammer drill setting. None of the 22 driving speeds is anywhere near as good for driving screws as an impact driver. – AndyT Jul 24 '18 at 13:20
  • @AndyT Ahh - thanks - I'd never heard of an impact drill; (I was very surprised that one could ever use a hammer drill to do anything but drill!) - I guess it's research time to learn how they work! – UKMonkey Jul 24 '18 at 13:23
    @AndyT Not going to disagree (impact drivers are the gold standard here), but if the OP's drill has a setting to make driving easier, why not note that? I use mine that way because I can't afford an impact driver at present. – Machavity Jul 24 '18 at 13:31
  • @UKMonkey - Not impact drill, impact **driver**. Because it is for **driving** not drilling. – AndyT Jul 24 '18 at 13:35
  • @UKMonkey an 'impact driver' is not the same thing as a 'hammer drill'. – JimmyJames Jul 24 '18 at 13:53
  • I'm not sure that 'vibrates' the screw is an accurate explanation. My understanding is that the impact driver essentially rotates back a small amount, starts it spinning to pick up some momentum and 'impacts' the driving bit using that rotational inertia. It feels like vibration in your arm but that's not the reason it drives screws so well. – JimmyJames Jul 24 '18 at 15:38
  • @JimmyJames I probably should have picked a better term. [Wikipedia has a good description of impact drivers](https://en.wikipedia.org/wiki/Impact_driver) – Machavity Jul 24 '18 at 15:41
I was having this same problem with small electronics. I am actually very surprised that I haven't seen anyone mention JIS (Japanese Industrial Standard) screwdrivers yet.
IIRC, Phillips head screws are actually specifically designed to cam out at a certain torque. This is due to the design of the head of the screw/screwdriver. Basically, the JIS is straighter so rather than cam out, it grabs.
Here is a good video demonstrating the difference between JIS and Phillips: https://www.youtube.com/watch?v=gEwVUZr5xxQ
The beauty of the JIS screwdriver is that it fits the Phillips screw so you can pick up a whole set of JIS screwdrivers and they are still universally usable.
Given how useful they are, it honestly amazes me that they are rarely found outside of Japan. (I actually had to order mine from Japan)
Bamboo
  • 283
Lots of feedback here, but I want to stress a point that others have mentioned in passing:
Star Drive, AKA "Torx"
I almost exclusively use "star drive" (AKA torx) "construction screws" such as these Grip-Rite construction screws or if you want, pan-head ones from Spax.
Impact Driver ≠ Drill
Also I've found an impact driver is much more effective. I own the Dewalt brushless model which I use for most "screwing" jobs. (If you already own other cordless tools like Milwaukee, Makita, etc. I'm sure the impact driver for any of them is decent.)
If I need, I can drive a 6" lag bolt through hard wood without pilot drilling. YMMV, unless you're doing rough work it's still a good idea to drill pilots so you don't crack the wood! But the issue is no longer stripping the screw head. I've literally snapped screws if I'm being careless and drive into something too hard, but I no longer worry about ever stripping a screw head.
Construction screws FTW!
thom_nic
  • 211
Totally agree with others here that hex, Torx, Pozidriv, etc are all better for most purposes since Philips are explicitly designed to cam out, which was needed for older automated assembly equipment that relied on that to stop from overdriving the screw, rather than just measuring torque and stopping on its own like any modern robot would.
I wanted to add one more thing for people to keep in mind for the situations when you only have the inferior Philips screws and a regular drill available though.
Many drills have a variable torque clutch thing (usually a ring around the chuck area that you can rotate). In general, try to start with this on the low end of the range and try driving in the screw. If it ratchets before you're done, you'll know you need more torque and can turn the torque up AND use more pressure to avoid camming out and stripping your head and bit all to pieces. The idea is to keep that clutch low enough so that you can't apply more torque than the screw can handle. If you need more torque, the drill will ratchet harmlessly instead of stripping your screw. When it happens, then I usually reposition myself to apply more force and then turn the torque up. The other nice thing about this is if you're driving say 10 screws into something, you can adjust the torque on the first one or two so that it ratchets right as you want it to stop, then you know you can drive the other 8 with just the right amount of torque to tighten it without overdriving it and potentially damaging your material, breaking off a head, etc.
XP84
  • 131
  • Phillips screwdrivers were NOT designed to cam out. That was an unintentional weakness in the design, not a deliberate goal. (Why limit torque by damaging the screw and/or screwdriver?) – Sneftel Jul 26 '18 at 22:08
  • @Sneftel - if you don't believe me, please see page 7 of the refinement of the patent, starting around line 37. You can go here and Ctrl-F for "most power" https://patents.google.com/patent/US2474994?oq=patent+2474994 – XP84 Sep 09 '18 at 05:40
  • @Sneftel The goal wasn't to damage the screw or driver, it was for the driver to pop out of the head as an alternative to accidentally snapping off the head or damaging the work. If I had to guess I'm guessing the socket in the screw head could take the abuse the one time they'd probably ever be turned, and the driver heads would wear anyway and be replaced and this was acceptable to them. Anyway, I'm glad we don't have a need for such a seemingly-garbage design today but wish we didn't still have these darn screw heads as a legacy of it! – XP84 Sep 09 '18 at 05:43
I try to use robertson (square) for most applications. With those, stripping the head is usually a case of using an incorrect bit size for the screw.
Jeremy
  • 121
I've been doing a lot of work over the last 3 years with high torque screws. The work has involved formwork for concrete, so it's got to be very strongly built and solid - everything is 2x4 inch (47x100mm) timber, sometimes 3x6 inch (75x100 mm). The screws have been ordinary wood screws but also 6 inch (150mm) heavy duty timber screws. I use a drill/drill driver rather than an impact driver, which has separate speed and torque control.
What I've found is a mix of things, maybe some of them will help:
  • Screw head - the screw head is crucial. Ordinary crosshead (Phillips) cam out or deform too easily. Pozidrive are good. But for pozidrive, the crucial thing is you need a bit+screw that's a tight fit, to make them work. A pozidrive that's a loose fit will have the same problems as ordinary phillips. Good brand removable pozidrive bits ("hex" style shank) are cheap - use those and buy a good brand. Beyond pozidrive, screws with hex and torx heads are ideal - they've never cammed out for me and are designed for high torque. But not all screws and sizes have them. They are also often more expensive, so you may wish to find ways to avoid them and get "ordinary" heads to work for you. The screws I use most are pozidrive (up to about 100mm) and hex/torx heavy duty heads (around 250+ mm).
  • Screw quality - I've noticed that some cheaper screws seem to be much softer, or the slots in the head are softer - they deform much more easily than other similar screws of other cheap brands. Try a couple of different screws of the same nominal size, and see if some of them go in and out multiple times , while others start to become deformed after just going in once, with tough wood/materials. I've had this even with big screws going into plastic plugs in concrete - there's one brand that just seems to have soft heads that never keep their slots, that I just don't use any more.
  • Speed control - going too fast means that when a camout happens, the bit will keep hammering the slots as it cams, and this harms both. Aim for slow/variable speed, high torque - and enough pressure to keep the bit held tightly in the slot. But aim for slow speed/high torque. Having a drill/driver with these as separate controls has been crucial. Often, going slow also means less torque - which is a problem.
Stilez
  • 610
You guys in the US need to find a way to import Robertson screws. They are by far the best screws high torque applications. The history goes like this
Robertson screw company was in a deal with Henry Ford himself. Ford wanted exclusivity for Robertson head screws for the Ford Motor Company. Robertson declined to grant exclusivity and Ford basically ran the Milton Ontario headquartered company out of the States. Now American products and all the American imports to Canada have those darn philips screws or hex screws. They just aren't very good for high torque applications. And the bits wear out extremely quickly.
Joe Fala
  • 6,314
  • 34
Rounding off Phillips head screws is something we have all experienced.
When unscrewing Phillip head screws that I know are not tight (from experience), I use a battery operated screwdriver. If they are tight, I try using a regular Phillips head screwdriver with the size (#1, #2, or #3) to match the screw. And, if it loosens, I then use that screwdriver, the battery operated one, or a drill, depending on how many screws there are to remove. Occasionally though the screwdriver will not turn the screw. Then I use an impact driver which you hit with a hammer. That always gets the really hard ones out.
getterdun
  • 1,725
There's been one mention of torque so far, but that answer didn't mention that you can often vary the maximum torque with a clutch. My 18V cordless (an older version of this one) has a collar to set the torque in steps up to 22, then drill, then hammer drill. Torque up to about 10 is good for most woodscrews, except small ones that I'd do by hand anyway. Torque 15 or more often snaps screws if they're not a type that can cam out but is good for coach screws.
Speed control is done with the trigger (actually mine has 2 ranges with a switch as well) and there's no need to go flat out when screwing, except in the middle of a really long screw - start slow and finish slow.
Chris H
  • 6,003
  • 27
