I have a new outlet (in an older house) with 4 hole socket and an older (4 years old) dryer. The dryer currently has a three pin plug.
What are my options for connecting the dryer to the newer outlet?
I did see New dryer, old outlet and How do I connect a dryer with a four prong plug to a three prong socket?, and I guess my question is just the reversed.
Is there a type of adapter that would work for this?
EDIT: With the accepted answer, I think I figure it out. The before picture:
The after picture with the 4 prong cord:
Does that look right? (The colors of the wires in the cord match the colors of the wires inside the dryer.)
Thomas
  • 145
    "four years old" is not old for a dryer. Your quite new dryer shipped with a modern 4-prong cord, but the previous owner had a *really* old house, so he changed it to a 3-prong cord. Change it back. – Harper - Reinstate Monica Jul 26 '18 at 01:27
  • @Harper: Yeah, I was surprised because I though the 4 year old dryer was "new". I think you are right. We got the dryer from Best Buy with installation. They didn't leave anything except the transport plugs. I did find a 4-prong cord at Home Depot today. – Thomas Jul 26 '18 at 13:56
  • Did they take away the hard copy of the user manual? – Jim Stewart Jul 26 '18 at 19:24
    Based on your picture, it looks like you did not remove: **"There will also be a wire attached to the same screw that the cord neutral lands on that runs off to the chassis; this wire will need to be removed from its terminal-block screw and left unterminated as it needs to be disconnected in a four-prong configuration."** That is VERY important. – manassehkatz-Moving 2 Codidact Jul 27 '18 at 01:30
  • @manassehkatz: So in terms of the wires on the pictures what does this mean? – Thomas Jul 27 '18 at 01:34
    From **what I can best guess without a specific model #** the white wire coming from inside the dryer to the green ground wire screw should be removed. But verification based on the installation manual for the dryer would be a *very good idea*. – manassehkatz-Moving 2 Codidact Jul 27 '18 at 02:13
    Can you post the make/model of this dryer? There should be a way to unhook that bonding jumper at the neutral end... – ThreePhaseEel Jul 27 '18 at 03:37
You need a new dryer cord, not an adapter
What you need to do is remove the existing cord from the dryer (dryer cords attach to a terminal block on the dryer, typically accessible by removing a cover from the back panel) and attach a new, four-prong/four-wire dryer cord to the terminal block. There is also a white wire running to the chassis ground screw on your dryer -- that wire needs to be moved from there to the neutral screw on the terminal block, thus disconnecting the neutral-ground bond on your dryer.
ThreePhaseEel
  • 81,744
  • 227
    The instructions for the dryer will show exactly how to do this for this dryer. If you don't have the printed instructions, look online for the instructions. – Jim Stewart Jul 26 '18 at 10:48
    @JimStewart: I am a bit worried about doing it myself, but maybe after a few Youtube videos I will do it. I love the internet :) – Thomas Jul 26 '18 at 13:57
    Be sure to take a picture of the way it is before you disconnect anything. Then take a picture of the connection block with the new plug and post both here as an edit to your question. – Jim Stewart Jul 26 '18 at 16:37
  • @JimStewart: Thanks Jim. I have edited the question and added the before and after picture. Does this look right? I matched the colors and added the green (ground?) wire. The hardest part was getting the metal thing to squeeze down around the new cord. – Thomas Jul 26 '18 at 22:51
    For our dryer the instructions are to place the neutral bonding jumper under the center screw on the connection block. So on your dryer the central screw will have two white wires under it. The purpose of this is to keep this jumper out of the way, but have it available if someone later would need to go back to a 3-wire cord. One could put electrical tape on the end on the jumper and leave it hanging but it is neater to have it corralled under a screw. – Jim Stewart Jul 27 '18 at 10:35
  • And for clarity here is a video showing the wiring: https://www.google.com/search?channel=fs&client=ubuntu&q=how+to+wire+a+four+plug+dryer+cable#kpvalbx=_5-VLYcGGMs34-wS54YnIDA55 – GBG Sep 23 '21 at 02:29
