I have the traditional two light at the left and at the right of my garage door. The are on the same circuit with the porch light that has a PIR sensor (turns on when move is detected).
So it is power source-->switch--Porch light--first light--second light
In the evening when we turn these lights on from inside the first light is flashing like those on the police cars :-), it keeps doing that for a while (can't say how long, it is not a regular interval) and then it stops flashing and it is solid on. Sometimes the same light turn off and stays like that
What could be the reason for this?
MiniMe
  • 3,400
  • 80
  • 134
    Does this answer your question? [What could cause flashing LED lights when other LED lights in a different room are turned on?](https://diy.stackexchange.com/questions/59611/what-could-cause-flashing-led-lights-when-other-led-lights-in-a-different-room-a) If not, many such questions have been posted. Short answer, try different bulbs or devices. – isherwood Feb 16 '20 at 15:45
  • Yes it points me to a possible smoking gun. I do have a chandelier which might be on the same circuit that has 9 of those spiral bulbs ..these are on a different switch but yes different bulbs (the outside ones are LED) . What does not make sense is why the other LED bulb is not flashing – MiniMe Feb 16 '20 at 15:49
  • It's the nature of the beast. I have two identical motion/light-sensing fixtures with two identical LEDs on the front of my garage. One blinks all day if the switch is on. One doesn't. – isherwood Feb 16 '20 at 16:01
  • Are there any smart switches, lighted switches, dimmers, anything like that in line? Is the PIR wired so the garage door lights come on when the PIR senses motion? – Harper - Reinstate Monica Feb 16 '20 at 16:49
  • no sensors, old school lighting. The only new era thing there is the PIR sensor No the PIR sensor turns on the porch light only. The garage lights used to have a senor but it is gone on both.. they are in parallel with the porch light bulb – MiniMe Feb 16 '20 at 16:53
  • @isherwood, which answer are you suggesting on that link? There are a few and none are accepted, as it is quite old most know about proper switches/ dimmers today. My guess is it’s a “good value” from our trading partner over seas because the op said not on pir. – Ed Beal Feb 17 '20 at 14:14
  • I'm not suggesting any particular answer, partly because we don't have a lot of information here. It's likely that one of them addresses the specific issue, though, or one on another question. – isherwood Feb 17 '20 at 14:16
  • I will have to try to see what solves the problem and get back and select the answer that was right on – MiniMe Feb 17 '20 at 15:13
0 Answers0
