16
a photo of the bolt in question
A previous owner fitted the light fitting pictured above, and has not left me a tool to remove the bolt. The bulb has blown so I need to get in to the unit. The head diameter is about 12mm and the gap between the two notches is about 6mm. I would like to remove it with some technique involving more finesse than simply smashing up the fitting and/or drilling out the bolt.
I hope someone can recognise the bolt and give me a search term which will let me cheaply buy a bit for this bolt from somewhere like Ebay UK.
ChrisF
  • 16,868
  • 74
Dickon Reed
  • 293
6 Answers6
17
I think that's a Spanner bit:
Four piece set
It's called a spanner slotted (or slotted spanner) head. Useful site here. Hard to find in the UK, why the owner used one I cannot imagine. Screwfix doesn't have them. This site may do, although it is international. You'll need to figure out the correct size before you order.
Alternatively get a real cheap flat-head screwdriver the right width and file down the middle until you get the right notch.
If you can grip it with a pliers try a pair of locking pliers and unscrewing it that way I keep a mini vise-grips handy for that sort of thing.
GdD
  • 5,209
    I usually bend a paperclip into a u shape, stick the two ends into the screw slots, then get a set of pliers and grab the paperclip right at the screw face... then turn. – Hightower Oct 09 '12 at 09:14
    Could work, depends on how tight it has been screwed in. – GdD Oct 09 '12 at 10:24
    You can also gang two thin screwdrivers together by clamping them between a pair of pieces of wood (to keep the alignment). If it's really stubborn, cut grooves in the wood so the screwdrivers don't spill. – Alex Feinman Oct 09 '12 at 12:59
    If you run into these with any regularity, you can find "security bit sets" online for ten's of dollars, which typically contain several sizes of spanner bits in addition to many others. Handy to have for those off times you run into these. – gregmac Mar 06 '14 at 22:47
  • I easily unscrew it by using a flat-head screwdriver, fiting the head in one of the slot and hitting the screwdriver to make it turn slowly. To screw the bolt back, I just saw its head, to make it as a regular flat-head bolt so I could use the flat-head screwdriver as normal. – MagTun Apr 23 '15 at 15:59
    Alternate solution would be to use a cutting disk with a rotary tool to carve out a straight slot between the notches in the screw head. Then you could just use a normal screwdriver to open the fitting, and you wouldn't have to go searching for your custom tool the *next* time the bulb burns out. – Wayfaring Stranger Nov 11 '15 at 16:05
Find a pair of scissors with a not-so-flimsy build, open them to the correct angle and insert the points into the two slots. If the screw is not too tight, this may work.
psmears
  • 178
X.X
  • 141
Variously known as a spanner-head, snake-eye or pig-nose screwdriver. I had exactly the same problem as the OP - I think I have the same light fixing. Presumably the idea of using a weird fixing is to protect from vandalism, but it's a right pain if you don't pass on the right tool to subsequent owners.
I put off replacing a blown bulb for months, looked all over for the right tool but couldn't find one. I was just about to start grinding a hole in an old screwdriver when I tried undoing it by hand, and found that it was only on finger-tight. So to anyone facing the same problem - try unscrewing it by hand!!!
Otherwise I suspect it's cheaper to smash up the fixing and buy a new fixing, than it is to order a special screwdriver from overseas.
El Sid
I took a simple screwdriver (AC tester actually) and cut the middle of it with a rotary grinder. It works for me to open these screws whenever I barge into them once in a few years. No need to search for rare bits for this one.
deE
I had one of these with a 12mm diameter head and about 6mm between the pins. Couldn't find the correct spanner / snake eye bit at all.
I brought a 10mm screwdriver and used a 6mm stone grinding bit in a dremel to shape it correctly. Took about 10 mins and worked great.
Suffice to say I replaced the weird security screws with normal ones after!
    This is _exactly_ what the second paragraph of [GdD's answer](https://diy.stackexchange.com/a/18768/34147) said. If you'd care to expand on this to offer something new... – FreeMan Feb 22 '22 at 12:54
  • It's also exactly what the complete [answer from deE](https://diy.stackexchange.com/a/77760/64567) is. – MarkL Feb 22 '22 at 18:27
