I have a small wooden table (ikea) where the legs screw into the table top.
The hole - into which one of the legs screw in - became wider, so now the leg is wobbly.
How would I fix this?
Is there a substance which I can refill the hole with and then drill a [narrower] hole into so that I can re screw the leg in tightly?
Brad Mace
  • 2,485
  • 48
Danield
  • 177
  • See also: http://diy.stackexchange.com/questions/5729/how-do-i-rehang-a-wooden-door-with-worn-screw-holes?rq=1 – BMitch Dec 31 '12 at 21:10
I'd use epoxy putty. It gets very hard and sticks tenaciously to almost anything. It would be a good idea to dig out the hole a little to make it larger at the bottom so the hard plug of dried epoxy is too big to come out of the hole. If it is IKEA it is probably particle board under veneer and wont offer much strength for the glue to stick, the surface is friable. This is why you should enlarge the hole, to give the glue a better chance of staying in place. Pack the hole with the putty. wait for it to harden overnight. Drill a hole appropriately sized for the fastener and screw it back in gently. Good as its gonna get for fixing IKEA.
timquinn
  • 118
