I'm planning to build a shelf in the garage, 22" deep and about 16' long. The back edge and one side will be supported by wall cleats, with 2x3s under the other edges. I'd like to support the front edge using steel cable from eye bolts in the shelf to eye bolts in the ceiling (truss framed) spaced every four feet other than the edge against the wall. (I like the idea of using cables because I think they'll create less obstruction when getting bins on or off the shelf.)
This shelf will hold about 16 of the large plastic totes, and I'd assume they'll be pretty full and heavy. I want to make this nice and sturdy, but I don't really have any sense of what size bolts and cable would be reasonable. I also want to make sure I'm not compromising the roof trusses with whatever I'm screwing into them or bolting through them. Any suggestions on sizes or attachment methods?
Brad Mace
  • 2,485
  • 48
    Is the shelf system running parallel or perpendicular to the trusses? If parallel, I'm thinking that's way too much of a load on the truss. – DA01 Apr 08 '13 at 03:31
  • @DA01 trusses are perpendicular so each cable would attach to a different truss – Brad Mace Apr 08 '13 at 04:32
  • That's definitely a better scenario. The trouble with roofing trusses is that they're really designed to hold up just the roof and some nominal amount above and beyond that. This is just me, but I'd probably opt for a solution that uses the concrete slab as the support...perhaps using iron pipes rather than cable. – DA01 Apr 08 '13 at 19:20
Shelf construction
If the shelf has its front open edge positioned such that at each four feet the cable would go up to a separate roof truss than I think that you have a workable system. Make sure that your 2x3's under the outer shelf edges are placed to that the nominal "3" inch dimension is vertical.
Hardware
Note that the lowest cost eyebolts, known as the "bent type eye bolt" are generally not recommended for lift and continuous tension applications. For this application it may be suggested to search out the drop forged type eye bolts as shown on the right below. These will cost more but they are actually specified for "lift" type applications.
bent eye bolt drop-forged eye bolt
If you do use the bent type, orient them so that the split end of the eye is up, as show above. Definitely use through-bolts rather than any type of screw-in eye.
eye screw
I would use 5/16" diameter eye bolts or larger.
Connection points
attachment points
Put the upper end of the cable through a threaded eye bolt that goes all the way through the side of the rafter truss and is secured in the far side with a washer and nut. Avoid the use of a screw eye type fastener. The eye bolt should be attached to the upper rafter part of the truss instead of the lower cross tie. When drilling the hole for the eye bolt position it in the upper part of the rafter as opposed to the lower portion.
Put the bottom end of the cable through an eye bolt that is long enough to go through the shelf material and the 2x3 and secure on the bottom with a washer and a nut.
Note that the orientation of the cable clamps is important, and it is always advisable to use two cable clamps for securing the cable.
Cable sizing
The size of cable is really dependent on the amount of load that you expect for the shelf. I would think that 3/16" diameter cable would be adequate for this application. The chart below will help to explain why I recommended 3/16" (assuming you use the 1x19 type of "stainless steel aircraft cable").
Brad Mace
  • 2,485
  • 48
Michael Karas
  • 64,093
  • 63
  • 142
  • I may be wrong, but I thought I recall learning a long time ago that for hanging, lag bolts have much stronger holding power than through-bolts. – DA01 Apr 08 '13 at 04:40
  • ah, I misread your answer. I see that these would be installed on the rafter part, so not entirely perpendicular. Scratch my previous comment, then! ;) – DA01 Apr 08 '13 at 04:59
  • So the top bolts would installed horizontally? Never occurred to me to attach to the upper truss member, but I see why that would be stronger. In my case the ceiling is already drywalled, so I'd have to find some sort of grommet for where the cables pass through the ceiling. Does it matter whether I use [ferrules like this](http://www.amazon.com/Brady-38090-Stainless-Steel-Clamps/dp/B003X270KA/) or the U-bolt style clamps? – Brad Mace Apr 08 '13 at 05:14
  • Also, I guessing I should use turnbuckles since I probably won't get them all exactly the right length to start with. Anything to be aware of there? – Brad Mace Apr 08 '13 at 05:15
  • @BradMace - I would use the clamp type as shown in my posting. – Michael Karas Apr 08 '13 at 05:25
    @BradMace - I see no need for turnbuckles. With the small diameter cable I recommended it should be easy to get the cable pulled through the eye bolts and clamped to the correct length. – Michael Karas Apr 08 '13 at 05:31
  • If you do use turnbuckles, be sure they are not the weakest link, check their working load rating, such that it is equal to or greater than the cable rating. – HerrBag Apr 08 '13 at 16:35
  • yes, the problem with the cable option is you have more 'weakest link' scenarios. The truss, the bolt, the cable, the turnbuckle, the clamp, the bolt on the shelf, etc. – DA01 Apr 08 '13 at 19:19
