I'll be closing on a house soon with a broken rafter, split opposite rafter and a twisted underpurlin that were all missed in the home inspection.
[Edit] These were missed during the home inspection. There was also mold in the attic from an improperly vented bathroom fan that the inspector found. After the mold was scraped and treated, I went up to inspect and found these. [\edit]
The split rafter I believe is easier to repair, as there is still enough there to sister onto. Is this the correct fix?
The broken rafter, I'm more concerned about sistering, as it is split along the full length. For both cases, I would be putting in new pieces almost the full length, but I haven't seen much in the way of what to do with sistering a broken rafter. Is this the correct fix for a fully split rafter?
The big question is what caused the split and broken rafter, I'm guessing something happened (someone jumped on that spot when they were re-shingling the roof and didn't notice the break?). I don't know if it's safe to assume I can just repair and move on, or if I should get a roofing guy in to take a look at it. I don't see any sagging yet, but I'm still new to this.
For the underpurlin, it is in contact with other rafters in its twisted state, so I am guessing that in that area the roof is sagging and leaning more on the underpurlin to cause it to twist like that. I'm not sure what the fix would be for this either. Adding more wood to reinforce it makes the most sense, just not sure how.
Any advice on if the fixes I'm suggesting are correct and other ideas would be greatly appreciated
Link to pictures: https://imgur.com/a/AdEWIod
