I have an RV and want to plug into the typical Nema 14-50 outlet found at campsites. However, I am never going to draw more than say 15amps. I would rather not have a heavy bulk cable that will never come close to its capacity.
In addition, it will be connected to an inverter that only takes 240V. It does not use the neutral. Therefore, I would like to use a 3 conductor 14gauge wire.
Clearly this would be bad if there was a short somewhere down stream of the outlet. The wire would get overloaded and burn. I am wondering if there are any in-line or outlet pluggable circuit breakers or fuses that can make this safe?
The idea would be to have a 15amp circuit breaker or fuse in the plug of the cord. Or a Nema 14-50P to Nema 6-15R converter, which would necessarily have some circuit breaker or fuse internal to it.
EDIT: I just found there are 14-50P to 6-15R adapters, but shouldn't there be some sort of fuse in this?
I'm not finding this to purchase, but maybe there is a different name?
Is this something one could build? I am not finding parts to do it easily. It would need to be somewhat water resistant.
What am I missing?
