Can I use a tap and die set to change screw threads? I'm having difficulty finding the right size of screws for my project, and wish to manufacture my own. Can any type of screws / bolts be used with a tap and die kit in this manner, or do they have to be made of a specific material?
P.S. Please tag this tap-and-die. – leeand00 Mar 23 '15 at 16:13
1Please try to be clearer about what you are actually doing or trying to do. – Ecnerwal Mar 23 '15 at 16:19
Tap and Die set is for making your own screws and bolts, does that help? I want to re-thread them, so I can just make whatever I need. – leeand00 Mar 23 '15 at 16:26
1Utterly the wrong approach, as @FreeMan has answered. I know darn well what a tap and die set is, I just found your intended misuse baffling. Now clarified, but still baffling. – Ecnerwal Mar 23 '15 at 16:34
@Ecnerwal Well what is the correct usage then? You have the rep to support your claim. – leeand00 Mar 23 '15 at 17:04
I don't think @Ecnerwal was trying to discern the general use of a Tap and Die set, but was simply trying to clarify your intention. – FreeMan Mar 23 '15 at 17:10
@leeand00: what is the problem you are trying to solve that you think rethreading fasteners is going to help with? What are you building or fixing? – whatsisname Mar 23 '15 at 17:11
I'm building a 3D Printer, and metric screws are so hard to come by. – leeand00 Mar 23 '15 at 17:23
5Metric screws are dead easy to come by. The local hardware store has a metric section if you want one or two (based on literally every local hardware store in my USA area) and if yours does not or you want to save a bit by bulk purchase, McMaster (or many other vendors) will have them shipped to you (you may need to buy 100 at once, but that's the cost-efficient way to do it anyway.) – Ecnerwal Mar 23 '15 at 20:21
4As for the question of "correct usage" to put threads where there were no threads (on a precisely sized bit of stock, for a die) (in a precisely sized hole, for a tap) or to repair threads that exist, are the same size and pitch as the tap or die, but which have some damage that the tap or die can cut away to restore function (but not full strength, as part of the thread will be missing). – Ecnerwal Mar 23 '15 at 20:36
Not really a home improvement question, but the answer is general enough that I'm not voting to close. – keshlam Mar 23 '15 at 23:37
Here's the tutorial that prompted me to go an buy the set: http://www.diynetwork.com/how-to/how-to-use-a-tap-and-die-set/index.html #3 "Turn a Steel Rod Into a Bolt". – leeand00 Mar 24 '15 at 03:28
linking to a worthwhile story of an example of a confused set of screw parameters being attributed to the wrong measurements where a 6mm 1.25 thread was mistaken for a 1/4" 20tpi screw. They're very close to each other. Just throwing it out there in case anyone else struggles with a "difficulty finding the right size of screws for a project" https://www.bikechatforums.com/viewtopic.php?t=228938 – jxramos Apr 20 '22 at 05:05
If you're trying to completely change the treading on a nut or bolt with a tap and die, I don't think that's going to work very well. You may be able to get a new thread pitch, but it will be interleaved with the existing one, and all you'd be doing is weakening the thread material.
If you need to simply fix some mangled threads, then have at.
If you're looking to cut your own bolt threads, you will probably want to start with unthreaded rod. Although, as Cathode mentioned in the comments, if you have hardened steel rods, you're in for a lot of frustration and not much success.
I suppose you could chuck the bolt into a lathe and carefully (very carefully) slice the existing threads off to give you an unthreaded rod with with a nice bolt head, but then you'd have to grab a box of nuts of sufficiently small size that once you ground the threads out of the inside the resulting diameter would match up with your newly "skinified" bolt stock & you could rethread those.
All in all, I'd head to the local big-box and grab a box of what you need for your current project. You'll have some spares for the next project, and will, eventually have a few dozen of everything lying around that you can't find.
- 43,073
- 21
- 81
- 173
6It should be mentioned that the grade of steel is going to determine success or failure. Trying to re-thread a grade 8 steel bolt will be an exercise in frustration. – William S. Mar 23 '15 at 16:59
Plus Grade 8 bolts usually have roll formed threads to prevent stress risers. Cut threads can leave the thread root susceptible to fatigue fracture. – Fiasco Labs Mar 24 '15 at 00:49
I'm a gunsmith. The issue for me is on older guns that had some non-standard (by today) TPI count (e.g 1/4 - 24) Today it's usually 20 TPI for coarse or 28 for fine. I didn't want to have to weld a hex top to drill bar. So now I keep on hand 1/4 bolts with long unthreaded shanks and cut the threaded end off and make custom bolts (surprisingly it's not hard to get the dies you need). Sometimes the obvious solution stares you in the face.
- 5,090
- 4
- 22
- 36
- 21
- 1
