12
I am planning to add Ethernet wiring to my house (semi-detached three-storey town house). I will be using this network to connect several (4-6) computers together in a typical (geek) home setting.
I have worked out the topology and most of the components, but there is one I am stuck on: the sockets. The quote I received from the electrician includes Cat 7 cables (probably overkill, but the difference in price to Cat 6 was minimal) and Cat 5 (RJ-45) sockets. I have a fairly good handle on Cat 5 / 6 / 7 cables, but the sockets have me stumped:
  • What does the Category (Cat) of an Ethernet socket signify?
  • If I connect Cat 5 sockets to Cat 7 cables, will I be limited to "Cat 5" speeds? Is the difference even likely to be noticeable in a home network?
  • My electrician claims that Cat 6 or Cat 7 sockets are very rare and almost never used. Is this the case? Some Googling has turned up the GG45 socket, which seems to be a backwards-compatible (with RJ-45) socket for Cat 7 cables - is this what I should be looking for? Or can I replace my Cat 5 sockets with Cat 7 sockets at a later date?
I'm still trying to get my head around this, so I apologise for the somewhat confusing questions, and would be most grateful if anyone can point me onto the correct path!
Lightsider
  • 223
Cat7 connectors are compatible with Cat5, with enhancements and caveats
Cat5, Cat5e, Cat6 and Cat7 are physically and electrically compatible. It's when you try to do 10Gb/s or higher signaling on the cable that the Cat5e standard falls over. Even at that, though, Cat5e will do 10Gbps out to 150 feet.
The physical connectors for Cat6 and Cat7 cables are still RJ45 plugs, but they're shielded and the standard calls for much less untwisting at the ends of the cable in the connectors than what is permissible for Cat5e. It's "harder" to do a proper Cat6 or Cat7 termination.
Aside from the wire twist requirements, in order for shielded connectors to work as designed, the grounding conductor in the cable has to be permanently in contact with the metal shield on the plug or jack when it is connected to the cable. You'll also see shielded Cat5e in installations like outdoor radio connections. Properly shielded cables also open up a whole new realm of potential issues like ground loop interference, so all of your equipment needs to be properly grounded, as well.
Performance
Anyhow... if you connect your Cat7 cable to Cat5e jacks, presuming your Cat5e jacks let you jam the thicker Cat7 wires in (which they almost certainly will), you can expect Cat5e performance. Cat5e performance is 1000 Mb/s (Gigabit Ethernet, or about 125 Megabytes per second). Properly terminated Cat5e will handle 10Gbps out to 150 feet, and Cat6 will handle 10Gbps out to 180 feet. Cat6 is often more than a job calls for, and costs twice as much.
Just for reference, if you have a mechanical hard drive in your computer, it's going to struggle to push more than 120 Megabytes per second. Gigabit Ethernet is every bit as fast as your internal hard drive throughput. If you have an SATA SSD, you may see 500 Megabytes per second, which is "faster" than Gigabit Ethernet. With the right switch, you can aggregate ports to create a 2 Gb/s, 3Gb/s, 4Gb/s or faster channel, but any single copy operation will only be able to saturate one of those aggregated links. If you have a PCI express SSD, it may be able to push over a Gigabyte per second, at which point you would need a 10Gbps network to come close to supporting the full throughput of that drive. But in practice, it's rare that you would need that kind of throughput over the network. A RAID built out of PCI express SSD's will support an absurd amount of throughput, at which point you would need to aggregate multiple 10Gbps links to fully support the throughput of the RAID array. But you don't need anything like that unless you're a big datacenter with big SANs and heavy virtualized workloads.
Personally, just to future-proof, I would consider running at least 2 Cat6 or Cat7 cables to every room if I was pulling new cable. But the chances of ever actually needing all that bandwidth are pretty low.
10Gbps Ethernet still costs over $100 per port right now, which is expensive for home use (you could get an 8 port 10Gbps switch for about $850).
It's unlikely that you need bigger bandwidth at your house than what Gigabit Ethernet provides today. On the other hand, I'd check the cost of Cat6 or Cat7 jacks and if you can bear the extra cost, have those installed instead of the Cat5e jacks.
Bear in mind that if your installer doesn't terminate those Cat6 or Cat7 jacks correctly (properly bonding the grounding conductor in the cable to the shielding, wire twist rules, etc.), then they aren't really Cat6/7 jacks, anyway. Your installer might know this, and might not want to go to the extra trouble if terminating those cables in full compliance with the standard.
Future of copper Ethernet
By the way, copper network cable has plenty of life ahead of it, out to 50 Gb/s or 100 Gb/s (well over 10 Gigabytes per second), depending on the standard and the cable. Ethernet over optical fiber follows essentially the same roadmap--same speeds--running out for several years, then jumps to bandwidth like 400Gb/s and higher. Who knows if copper will continue to support those kinds of speeds. But are you really worried about being able to move so much data around your home network that 50Gb/s or 100Gb/s couldn't meet your needs? So you can install fiber if you really want to, but you're going to pay a lot more for every port for a zero or negligible benefit if you go that route.
Having said all that, I actually do strongly agree with the notion of running conduit so that you can pull new cable later. Because who knows what's really coming a few years out? One reasonable way to do this is to run the conduits straight up the wall channel from the wall boxes into the attic. You can pull cable straight up into the attic, then run it through the attic suspended from the roof trusses or even strung across the joists.
But in terms of future-proofing, take a look at the Ethernet Roadmap document from the Ethernet Alliance.
Craig Tullis
  • 5,866
  • $1,0000 per port? You can get a 24-port 10gbps ethernet switch for under $3K, e.g. $150 per port max. Still expensive, of course, but not even close to what you said. Also, what you said about port aggregation is a bit misleading. Yes, you can aggregate several ports, but any one stream will still be limited by one port, so if, say, you're copying files, you'll still be limited by 1Gbps connection even if you aggregated 2 of them. – haimg Mar 08 '16 at 00:37
  • Yeah, typo--corrected. Link aggregation is for increased bandwidth and decreased contention. For one thing, you wouldn't do link aggregation (probably) from a workstation anyway. You might with a server. But even then, there are examples of software that fork or spin up additional threads and create multiple streams, so it is possible to do file transfers from one machine that will use multiple links simultaneously. Plus, a server is usually servicing multiple independent, concurrent requests and link aggregation is a plus in that scenario. – Craig Tullis Mar 12 '16 at 23:56
The word you need to know here is shielding. Cat 5e doesn't afford you much shielding, but the slower speeds it means it's not as susceptible to interference. Cat 5e relies on the twisting of the wires alone to provide enough shielding. Cat 6 adds a plastic piece between the wires. Cat 7 has foil wrapped pairs and overall shielding
Cat 7 wire
You can easily send 1Gb of data down either wire, but as you ramp up the bandwidth, the more susceptible the data becomes to interference, thus slowing the bandwidth. The longer the run, the more the signal suffers (Cat 7 supports 100M/328ft 10Gb data transfer). If you add any Cat5e parts (plugs, keystones, etc) inside, it will not support that speed.
RJ45 is all Newegg & TigerDirect offer on their Cat7's, so I'd have to say no problem with the old connectors. And, your computers won't take anything else...without a specific expansion card being installed.
Cat & whatever number is just for Category & level speed or data transfer rate, none of that has anything to do with the end connectors. There are a variety of end connectors depending on the equipment they're attached to, you only want something that fits your computers, Router & Modem.
So yes, you can simply clip-off the old connectors & replace them later with GG45, ARJ45 or whatever else the future might have that utilizes your twisted pairs. Your Cat7's do have room for another 2 increases...IF they even happen, copper's on the way out. You'll be happy for a while.
I think Cat7 was a warning to replace everything, just buying everyone a little more time. But, Digital is the future & your planned wires won't do diddly in that future & will need to be replaced entirely with fiber optics, since those can't use any connectors that copper used.
If you see yourself there for 10-years or more. Have the electrician run the cables in conduit so you can drag out the old & slide in the new.
Iggy
  • 10,287
  • [The death of copper has been greatly exaggerated](http://www.ethernetalliance.org/wp-content/uploads/2015/03/Ethernet-Roadmap-2sides-Final-5Mar.pdf). ;-) – Craig Tullis Mar 07 '16 at 17:25
  • Oh, it had a great run. I mean, look at all the lies the Cable Companies got away with ...we can't do more than 1mbps ...3mbps ...5mbps ...10mbps ...20mbps ...50mbps so sign up today for our best offer ever! – Iggy Mar 07 '16 at 19:16
    Technology changes. Have a look at the background of [DOCSIS](https://en.wikipedia.org/wiki/DOCSIS) (the broadband protocol used for cable company Internet). Before DOCSIS 3.0, transmissions could only use a single channel, and the total bandwidth available in the standard is shared with all of the neighbors connected to the same node. As technology improves and they get more fiber closer to users, they offer higher bandwidth. Also, copper coax broadband is *not* Ethernet over TP cable. ;-) – Craig Tullis Mar 07 '16 at 19:34
  • I think it's important to try not to compare apples and oranges. Metro Gigabit Ethernet is not likely to be delivered to the home (exclusively) over copper because the distances involved are too great. But within a local network (up to 330 feet in any direction from your Ethernet switch), copper is alive and well. The OP is talking about networking within a home, not talking about internetworking over long distances outside the home, which is the use case for things like broadband cable, DSL, FIOS and metro Ethernet. Different context. ;-) – Craig Tullis Mar 07 '16 at 19:39
  • I know-I know, it was just an example of the nonsense. Want a trip in the way back machine? I was a DOS baby & only now does the GUI software crap finally meet the "user performance" of a Pentium1. Because of the GUI crap, I still can't get instant (no wait, lag, hesitation AT ALL) anything, though I suspect that's a lie if the Gov't & their buddies weren't snooping everyone & piggybacking everything. – Iggy Mar 07 '16 at 20:05
  • I've designed entire subdivisions in the distant past on a 16Mhz 80386 with AutoCAD, in 4 Megabytes of RAM (using the Pharlap extended memory manager, of course) on a 20 Megabyte hard drive. I get it. ;-) – Craig Tullis Mar 07 '16 at 21:18
  • Of course, my 3.4Ghz Core i7, with 4 cores plus hyperthreading, running Windows 10 in 16GB of RAM off an SSD with a big mechanical HDD for extra storage and a quad-port AMD FirePro graphics card and three HD monitors gets me by alright. And let's be honest, StackOverflow on DOS would kinda suck. :-) – Craig Tullis Mar 07 '16 at 21:25
  • Funny stuff. I miss Win95. – Iggy Mar 07 '16 at 22:55
  • I don't miss Win95 at all. It was an *awful* hack: Sure it ran 32 bit apps, but under the hood, it still had a 16 bit kernel. In particular, all the VxD device drivers were 16 bit, this included your display driver. A little history for you now: MS never wanted to release Win ME, I was at WinHec 1998 in Orlando and MS swore up and down Win 98 was the last 16 bit kernel they were doing. But they couldn't get Win 2000 Home working soon enough, so we got ME to tide us over till the release of XP, complete with a Home version. – dgnuff Jan 04 '18 at 03:18
  • Nice! Of course you're right, depending on the application. However, I and the overwhelming majority really don't do anything that the earliest GUI platforms couldn't run incredibly. But then, you get into the no functionality with today's multi-core and multi-threading processors. There's no benefit nor need to get off of the VGA port even yet, for that majority of users. It's pretty sad that even with forced obsolescence that Microsoft has only had baby-step advancement in over 20-years, reverting back to Win95 type simplicity to fix their consistent history of bad ideas and poor execution. – Iggy Jan 04 '18 at 12:02
