API v0.4
This page describes a historic artifact in the history of OpenStreetMap. It does not reflect the current situation, but instead documents the historical concepts, issues, or ideas.
Historical Interest Only. Version 0.4 no longer in use
This document describes OSM API v0.4 which is no longer in use. We stopped using version 0.4 in October 2007. See the API page for a link to the currently active protocol specifications.
OSM API Version 0.4
In order to keep the specification unambiguous, this specification uses terms shall, may and can in line with the IEEE Style Guide.
The OSM API is based on the HTTP-Protocol. Please have a look at the corresponding OSM document HTTP Protocol Specification.
The RESTful API
This Protocol is based on the ideas of the RESTful API. For more information on RESTful APIs see wikipedia's Representational State Transfer page.
As this protocol described below, the REST APIs uses HTTP-Methods like GET_request, PUT and DELETE in conjunction with XML payload send to URLs.
Protocol Roles
This OSM Protocol currently has two different protocol protocol roles.
OSM Protocol role client
The OSM client sends request messages to the OSM server.
Examples of OSM clients are:
OSM Protocol role server
Upon reception of a request from the OSM client, the OSM server shall answer with a response message.
Examples of OSM servers are:
Transport
The OSM Protocol Version 0.4 uses the URL of the HTTP-request to transport data from the OSM client to the OSM server. It uses HTTP/1.1 commands to transfer data between the OSM client and the OSM server.
General HTTP-Transport format
According to RFC 2616 the HTTP URLs have the following format:
http_URL = "http:"  "//" host [ ":" port ] [ abs_path ["?" query ]]
Where the content with brackets [ ] is optional.
OSM specific HTTP-Transport format configuration
When the HTTP-Transport is used in conjunction with the OSM-Protocol, the absolute path ('abs_path') is split into an identifier of the OSM Protocol Version e.g. "api/0.3" or "api/0.4" and the OSM_Protocol_Command separated by a slash "/".
When HTTP is used as transport for the OSM protocol, the URL is shall be created from the OSM_Protocol_Version, the OSM_Protocol_Command and the optional OSM_Command_Parameters as following:
http_URL = OSM_Protocol_Version OSM_Protocol_Command ["?" OSM_Command_Parameters]
Where: OSM_Protocol_Version: Specifies the used OSM Protocol Version and shall for the OSM Protocol Version 0.4 always be defined as "/api/0.4".
OSM_Protocol_Command: Specifies the OSM Command to be executed at the OSM Server.
OSM_Command_Parameters: Specifies the OSM Command Parameters to be passed with the OSM Command to the OSM Server. If OSM_Command_Parameters is empty, they shall just be left away. If OSM_Command_Parameters is not empty, the parameters shall become preceded with a "?".
Examples:
/api/0.4/way/search?type=highway&value=motorway
/api/0.4/segment/create
For the OSM Protocol Version 0.4 all applicable commands and their parameters are defined in the following sections.
Used HTTP Methods
The OSM protocol uses the following methods provided by the lower HTTP-protocol layer:
  • GET
  • PUT
  • DELETE
Additionally are prvovided by lower HTTP-protocol layer:
  • Status Codes
  • Authentication
HTTP GET-Method based commands
The following OSM-protocol commands use the HTTP-Method GET provided by the lower HTTP-protocol layer.
Get node by NodeID
If the OSM server receives the GET_request message containing:
MethodOSM_Protocol_CommandOSM_Command_Parameters
GET_request/node/NodeID
upon successful command execution, the OSM server shall respond with a GET_response message containing:
Methodget_response_body
GET_responseXML DTD Schema:
<!ELEMENT osm (node)>
<!ATTLIST osm version CDATA #REQUIRED>
<!ATTLIST osm generator CDATA #REQUIRED>
<!ELEMENT node (tag*)>
<!ATTLIST node id CDATA #REQUIRED>
<!ATTLIST node lat CDATA #REQUIRED>
<!ATTLIST node lon CDATA #REQUIRED>
<!ATTLIST node timestamp CDATA #REQUIRED>
<!ATTLIST node user CDATA #IMPLIED>
<!ATTLIST node visible CDATA #IMPLIED>
<!ELEMENT tag EMPTY>
<!ATTLIST tag k CDATA #REQUIRED>
<!ATTLIST tag v CDATA #REQUIRED>
Where NodeID identifies a node and shall be of the type OSMIdentifierType.
Applicable Status Codes of the GET_response message are:
Status CodeDescription
OKThe requested node identified by the given NodeID could be successfully be retrieved.
Bad RequestNot applicable.
UnauthorizedUser authentication of HTTP Protocol failed.
Not FoundThe node identified by NodeID had never existed.
GoneThe node identified by NodeID had existed, however does no longer exist.
Precondition FailedNot applicable.
Internal Server ErrorThe server encountered an unexpected problem.
Example GET_request message:
https://api.openstreetmap.org/api/0.4/node/156804
Example GET_response message:
<?xml version="1.0" encoding="UTF-8"?>
<osm version="0.4" generator="OpenStreetMap server">
 <node id="156804" lat="61.8083953857422" lon="10.8497076034546" visible="true" timestamp="2005-07-30T14:27:12+01:00"/>
</osm>
Get segment by SegmentID
GET_request/segment/SegmentID
<!ELEMENT osm (segment)>
<!ELEMENT segment (tag*)>
<!ATTLIST segment id CDATA #REQUIRED>
<!ATTLIST segment from CDATA #REQUIRED>
<!ATTLIST segment to CDATA #REQUIRED>
<!ATTLIST segment user CDATA #IMPLIED>
<!ATTLIST segment visible CDATA #IMPLIED>
<!ATTLIST segment timestamp CDATA #REQUIRED>
Where SegemntID identifies a segment and shall be of the type OSMIdentifierType.
OKThe requested segment identified by the given SegementID could be successfully be retrieved.
Not FoundThe segment identified by SegmentID had never existed.
GoneThe segment identified by SegmentID had existed, however does no longer exist.
https://api.openstreetmap.org/api/0.4/segment/156804
  <segment id="156804" from="200542" to="200550" user="blackadder" visible="true" timestamp="2005-11-08T17:28:52+00:00">
    <tag k="name" v="Fire Route"/>
  </segment>
</osm>
Get way history by ID
GET_request/way/WayID/history
<!ELEMENT osm (way+)>
<!ELEMENT way (seg+, tag*)>
<!ATTLIST way id CDATA #REQUIRED>
<!ATTLIST way visible CDATA #IMPLIED>
<!ATTLIST way timestamp CDATA #REQUIRED>
<!ATTLIST way user CDATA #IMPLIED>
<!ELEMENT seg EMPTY>
<!ATTLIST seg id CDATA #REQUIRED>
Where WayID identifies a way and shall be of the type OSMIdentifierType.
OKThe requested history of the way identifed by the given WayID could be successfully be retrieved.
Not FoundThe way identified by WayID had never existed.
GoneNot applicable.
https://api.openstreetmap.org/api/0.4/way/35/history
 <way id="35" visible="true" timestamp="2006-03-14T10:07:23+00:00" user="blackadder">
  <seg id="156804"/>
  <seg id="156805"/>
  <seg id="156806"/>
  <tag k="created_by" v="JOSM"/>
</way>
 <way id="35" visible="true" timestamp="2006-03-14T10:10:44+00:00" user="blackadder">
  <seg id="156804"/>
  <seg id="156805"/>
  <seg id="156806"/>
  <tag k="created_by" v="[email protected] - JOSM"/>
  <tag k="construction" v="paved"/>
  <tag k="type" v="Footway"/>
 </way>
 <way id="35" visible="true" timestamp="2006-03-14T10:17:44+00:00" user="blackadder">
  <seg id="156804"/>
  <seg id="156805"/>
  <seg id="156806"/>
  <tag k="id" v="AJR000002"/>
</way>
Get way by ID
<!ELEMENT osm (way)>
OKThe requested way identified by the given WayID could be successfully be retrieved.
GoneThe way identified by WayID had existed, however does no longer exist.
   <way id="35" visible="true" timestamp="2006-03-22T21:55:13+00:00" user="blackadder">
     <seg id="156804"/>
     <seg id="156805"/>
     <seg id="156806"/>
     <tag k="place_name" v="Sutton Coldfield"/>
     <tag k="highway" v="footway"/>
     <tag k="surface" v="paved"/>
     <tag k="note" v="fire access route"/>
   </way>
</osm>
Get ways
GET_request/ways?ways=id1,id2,id3...
<!ELEMENT osm (way*)>
OKThe requested ways identfied by the given list of WayIDs could be successfully be retrieved.
  • Please clarify what happens when none of the ways identified by the given list of WayIDs could be successfully retrieved. Does error code 'not found' apply then? Please help fixing!!!!!!!!!!!!!!!
  • Please clarify what happens when only some of the ways identified by the given list of WayIDs could be successfully retrieved, however at least one way identified by the list of WayIDs could not be supplied. Is any information provided within the error code or the payload supplied within the Get_response message? Please help fixing!!!!!!!!!!!!!!!
Bad RequestNo wayIDs were provided.
Not FoundNot applicable.
GoneNot applicable.
https://api.openstreetmap.org/api/0.4/ways?ways=35,38
   <seg id="156804"/>
   <seg id="156805"/>
   <seg id="156806"/>
 </way>
 <way id="38" visible="true" timestamp="2006-03-16T09:50:36+00:00" user="blackadder">
   <seg id="230688"/>
   <seg id="230689"/>
   <seg id="230690"/>
   <seg id="230691"/>
   <seg id="230693"/>
   <seg id="230694"/>
   <seg id="230696"/>
   <tag k="place" v="Sutton Coldfield"/>
   <tag k="id" v="AJR000003"/>
 </way>
</osm>
Get map
Map is the heart of things here. It will provide a bundle of nodes, line segments, and ways given some bounding box. The XML returned will give you the ways that any of the segments within that bounding box belong to, and (as opposed to protocol version 0.3) will also give you all the segments that those ways own and their nodes, even if these lie outside the given bounding box.
The bounding box is specified in one parameter, bbox, giving the longitude and latitude of the bottom left corner first, then the longitude and latitude of the top right corner.
Note: In the interests of keeping the API snappy, it is restricted to providing data for only moderately sized areas (currently 0.25 deg). If you don't need the very latest data, or if you need lots of data, you should use Planet.osm instead.
GET_request/map?bbox=bllon,bllat,trlon,trlat
Upon successful command execution, the OSM server shall respond with a GET_response message containing:
<!ELEMENT osm (node+, segment*, way*)>
<!ELEMENT way (seg+,tag*)>
<!ATTLIST tag k CDATA #IMPLIED>
Methodstatus_code
GET_responseBad Request
Where:
ParameterType DefinitionDescription
bllonOSMlonTypelongitude of the bottom left corner of the bounding box (minimum longitude)
bllatOSMlatTypelatitude of the bottom left corner of the bounding box (minimum latitude)
trlonOSMlonTypelongitude of the top right corner of the bounding box (maximum longitude)
trlatOSMlatTypelatitude of the top right corner of the bounding box (maximum latitude)
GMT_TimeOSMDateTypeoptional, the time to fetch the data for (default is latest data)
OKThe map data of the requested bounding box has successfully been retrieved.
Bad RequestIf the requested area is too large. The area limit is currently ~0.1 square degrees. If a larger area is needed, please use Planet.osm.
Not Foundapplicable? please help fixing!!!
Goneapplicable? please help fixing!!!
Get map trace examples are found here: Get map trace example
https://api.openstreetmap.org/api/0.4/map?bbox=11.54,48.14,11.543,48.145
Search objects (ways, segments and nodes)
You can search by type, value, or both. This will search the tags on all the objects (nodes, segments and ways)
GET_requestsearchtype=keyA
value=keyB or type=keyA&value=keyB
GET_responsetbd.tbd.
The URL to GET is /search and the parameters are type and value
Example:
  • /search?type=highway
  • /search?value=Cambridge
  • /search?type=railway&value=rail
The response is all the matching nodes, segments and ways
OKProvide description here. Please help fixing!!!
Bad Requestapplicable? please help fixing!!!
Precondition Failedapplicable? please help fixing!!!
Search nodes
This command is used to search by node type, node value, or both.
GET_request/nodes/searchtype=keyA
Examples:
The URL to GET is /nodes/search and the parameters are type and value.
eg:
  • /nodes/search?type=highway
  • /nodes/search?value=Oxford
  • /nodes/search?type=place&value=town
If matching nodes are found the OSM server shall respond with a GET_response message containing:
Search segments
You can search by segment type, segment value, or both
This command might be incorrect. Please help fixing it. If the OSM server receives the GET_request message containing:
GET_request/segments/searchtype=keyA
The URL to GET is /segments/search and the parameters are type and value
Example:
  • /segments/search?type=highway
  • /segments/search?value=Oxford Street
  • /segments/search?type=highway&value=secondary
The response contains the segments that match.
Search ways
You can search by way type, node value, or both
GET_request/ways/searchtype=keyA
The URL to GET is /ways/search and the parameters are type and value
Example:
  • /ways/search?type=highway
  • /ways/search?value=M1
  • /ways/search?type=highway&value=motorway
The response contains all matching ways.
Get gpx files of the user
GET_request/user/gpx_files
Create gpx file
Operation purpose is unclear. Is this GET or PUT procedure used for this method. Please fix! If the OSM server receives a POST_request message containing:
POST_request/gpx/createdescription, tags, public, file
upon successful command execution, the OSM server shall respond with a POST_response message containing:
POST_responsetbd.tbd.
Where:
descriptionOSMTextStringTypeDescription for GPX file.
tagsOSMTextStringTypeTags to associate with GPX file.
publicOSMTextStringTypeBoolean flag to indicate whether file is public or not.
fileOSMTextStringTypeGPX file contents.
Bad RequestThe supplied arguments were not acceptable.
GoneNot applicable.
Get GPX file details by ID
GET_request/gpx/NameID/details
Where NameID identifies a filename and shall be of the type OSMIdentifierType
Not FoundIf the gpx file identified by NameID has not been found? for all or for this user? please help fixing!!!
GoneIf the gpx file identified by NameID had existed, however does no longer exist? for all or for this user? please help fixing!!!
Get Trackpoints
The XML returned will give you a page of uploaded track points within the bounding box. Newer points are returned first.
Results are divided into pages of 5000 points. The zero based page parameter specifies which page of results is required.
GET_request/trackpoints?bbox=bllon,bllat,trlon,trlat&page=pagenumber
GET_response
<!ELEMENT gpx (trk)>
<!ATTLIST gpx version CDATA #REQUIRED>
<!ATTLIST gpx creator CDATA #REQUIRED>
<!ELEMENT trk (trkseg)>
<!ELEMENT trkseg (trkpt*)>
<!ELEMENT trkpt EMPTY>
Where:
pageOSMTrackpointPageTypeThe zero based page parameter indicating which page of 5000 points required
 https://api.openstreetmap.org/api/0.4/trackpoints?bbox=-1.22,51.86,-1.10,51.97&page=0
<gpx version="1.0" creator="OpenStreetMap.org" xmlns="http://www.topografix.com/GPX/1/0/">
  <trk>
    <trkseg>
      <trkpt lat="51.896232" lon="-1.148553"/>
      <trkpt lat="51.896255" lon="-1.148459"/>
      <trkpt lat="51.896275" lon="-1.148361"/>
    </trkseg>
  </trk>
</gpx>
OKThe page of track points within the requested bounding box has successfully been retrieved.
Bad Request
  • If the requested area is too large. The area limit is currently ~0.1 square degrees.
  • If the page parameter is not greater than or equal to 0.
HTTP PUT-Method based commands
The following OSM-protocol commands use the HTTP-Method PUT provided by the lower HTTP-protocol layer.
Create new node
MethodOSM_Protocol_CommandOSM_Command_Parametersput_request_body
PUT_request/node/createnode_payload
upon successful command execution, the OSM server shall respond with a PUT_response message containing:
HTTP MethodHTTP Message-Body
PUT_responsetbd.
Applicable Status Codes of the PUT_response message are:
GoneNot applicable.
Precondition FailedThe XML data transported as node_payload contained a NodeID.
Create new node trace examples are found here: Create new node trace example
Create new segment
PUT_request/segment/createsegment_payload
PUT_responsetbd.
GoneNot applicable.
Precondition Failed
  • The XML data transported as segment_payload contained a SegmentID.
  • The XML data transported as segment_payload contained less or more than two NodeIDs.
  • The XML data transported as segment_payload contained two identical NodeIDs for segment start and segment end.
  • The XML data transported as segment_payload contained the NodeID of one or more deleted nodes.
  • The XML data transported as segment_payload contained the NodeID of one or more not existing. nodes.
Create new segment trace examples are found here: Create new segment trace example
Create new way
PUT_request/way/createway_payload
PUT_responsetbd.
GoneNot applicable.
Precondition Failed
  • The XML data transported as way_payload contained a WayID.
  • The XML data transported as way_payload contained zero SegmentIDs.
  • The XML data transported as way_payload contained the SegmentID of one or more deleted segments.
  • The XML data transported as way_payload contained the SegmentID of one or more not existing segments.
Create new way trace examples are found here: Create new way trace example
Store node by ID
PUT_request/node/NodeIDnode_payload
PUT_responsetbd.
Bad RequestID in XML didn't match ID in request
Not FoundNode to update did not exist
GoneNode to update has been deleted (resurrection is not possible this way)
Precondition Failed
Store segment by ID
PUT_request/segment/SegmentIDsegment_payload
PUT_responsetbd.
Where SegmentID identifies a segment and shall be of the type OSMIdentifierType.
GoneNot applicable.
Precondition Failed
Store way by ID
PUT_request/way/WayIDway_payload
PUT_responsetbd.
GoneNot applicable.
Precondition Failed
HTTP DELETE-Method based commands
The following OSM-protocol commands use the HTTP-Method DELETE provided by the lower HTTP-protocol layer.
Delete node by ID
DELETE_response/node/NodeID
upon successful command execution, the OSM server shall respond with a DELETE_response message containing:
DELETE_responsetbd.
Applicable Status Codes of the DELETE_response message are:
OKThe node identified by NodeID had been successfully deleted.
GoneThe node identified by NodeID had existed, however does not longer exist.
Precondition FailedThe node could not be deleted because it is in use by a segment.
Delete node by ID trace examples are found here: Delete node by ID trace example
Delete segment by ID
DELETE_response/segment/SegmentID
DELETE_responsetbd.
OKThe segment identified by SegmentID had been successfully deleted.
GoneThe segment identified by SegmentID had existed, however does not longer exist.
Precondition FailedThe segmnet could not be deleted because it is in use by a way.
Delete segment by ID trace examples are found here: Delete segment by ID trace example. Please help by providing a suitable trace file!!!!
Delete way by ID
DELETE_response/way/WayID
DELETE_responsetbd.
OKThe way identified by WayID
GoneThe way identified by WayID had existed, however does not longer exist.
Delete way by ID trace examples are found here: Delete way by ID trace example. Please help by providing a suitable trace file!!!!
Error Text
In the event of an error, the OSM server response will have a status_code set to bad request. In some cases, it will also include an additional HTTP header, Error. Where the HTTP header Error is present, the Error header provides a textual description of the failure.
eg
 HTTP/1.1 400 Bad Request
 Cache-Control: no-cache
 Connection: Keep-Alive
 Error: The maximum bbox size is 0.25, and your request was too large. Either request a
 smaller area, or use planet.osm
 Date: Sun, 29 Apr 2007 09:31:51 GMT
 Content-Type: text/xml; charset=utf-8
 Server: WEBrick/1.3.1 (Ruby/1.8.5/2006-08-25)
 Content-Length: 1
Error handling
The OSM Protocol uses the Error Handling of the low HTTP Layer. For more information on Error Handling, please see HTTP Protocol Specification.
Type definitions
StatusCodeType
The status codes are defined by the HTTP Protocol Specification
OSMIdentifierType
The OSMIdentifierType shall be a unsigned 64-Bit Integer.
Encoding (as part of an OSM command):
  • As decimal number [1 .. ((2^64)-1)]
  • Leading zeros may be omitted.
Please verify that the above statement is correct!!!
OSMTextStringType
The OSMTextStringTyp shall be a sequence of UTF-8 characters.
Is UTF-8 characters correct or should it be ASCII characters? Please help fixing it.
OSMlonType
The OSMlonType shall be an integer number in the range of -180 to +180 degrees.
'Please provide more info below. How many digits after the comma or dot?' E.g. XXX.YYYY -XXX.YYYY +XXX.YYYY
Where: - the "." and YYYY may be left away if "YYYY" is equal to "0000" - tailing "0" of YYYY may be left away - leading "0"s of XXX may be left away - the "+" may be left away Are the following accepted?
179. instead of 179 or 179.0 .4 instead of 0.4
OSMlatType
The OSMlonType shall be an integer number in the range of -90 to +90.
OSMDateType
This should be either of the form YYYY-MM-DD or YYYY-MM-DD hh:mm:ss (Don't forget to encode the space as %20)
The OSMTrackpointPageType shall be an integer number greater than or equal to 0.
Status Codes
The OSM Database Access Protocol shall use the status_codes defined by HTTP Protocol Specification.
Encoding of Error Text
Please help fixing this part.
Encoding of error_text parameter shall be ???ASCII or UTF-8 text string???
Please provide input on the text string type!!!
